Hey guys i have an issue where the 3 bank stops too high up on the playfield when in the down position. Around 10mm too high. The switches for the high and low have no adjustment. and the motor has a flat edge on the shaft so the grub screw can only lock it in one position. What is it that i am not seeing that will help it's final resting place be flush with the playfield.
Thanks in advance
