In a nutshell, the Q15 transistor went bad causing the coil to lock on with the flipper up.
I removed the old transistor with no problems and then went on to lift two of the pads while trying to remove the leftover solder. Is there anyone who can fix this for me and solder in the new transistor (and one other transistor that went out, that one drives the left flashers in the back panel)? Very disappointed in myself for effing up the pads, Ive succesfully replaced transistors on Williams boards before and had no trouble, but this board no such luck. So Id rather send it off to a pro. Please let me know if anyone is willing/able to take on this board repair, thank you.
