I just replaced all of my ramps on white water.holy cow does the game looks so much better now The gameplay is back to normal with one exception if I hit the ball with the upper flipper it sometimes launches it as high as hitting the sign with the two colored bulbs right there. 9 times out of 10 it works perfectly and the flipper has no slop to it, the upper playfield was installed and tightened down and the rubber looks fine on the flipper bat. I have had the game for a few years and never had this happen but cannot figure out what would cause it.
I was thinking maybe the upper playfield was at a weird angle but it is all tightened down snug.
I thought maybe someone may have had the same issue and might be able to steer me in the right direction. Thank you!
