Bought a player #Whitewater without 1) topper, 2) power harness 3) Light chase driver board 4) 8-lamp boards 5) Lamp chase driver board to the 8-lamp board wiring harness and 6) the power harness between the Light chase driver board and the power driver board.
It made me sad - so over the last year or so I slowly gathered the parts.
I re-capped/rebuilt my power driver board to be sure it's reliable and have finally assembled everything I *think* I need to re-install a topper.
In the past I've found that the Williams manuals are not always 100% correct and so wanted to validate my assumptions with one of the other 7007 potential WH2O owners any of which I'm sure are smarter than I.
Ordered the .100" KK Molex connectors and pins to build the Light Chase driver board to 8-lamp board cable.
I need to order some 22 AWG stranded copper wire and wanted to know how much to get. (Hoping 250' may be enough?)
Knowing how long the original cables are would really help. If anyone can please measure their cable it would be appreciated! A picture of the same would be really awesome too!
Picked up this low cost LED Light Chase board as a kit put it together tonight. www.ebay.co.uk/itm/324992478937
Other than J1 Pins 1 & 2 not being connected to anything on the chase board the pinouts of J1, J2, and J3 on this chase board are identical to the original chase board if the manual is correct.
Looks like J118 Pins 2&3 is my +12 and Ground on J1 Pins 4&7.
They offer a different version for the old incandescent bulbs, but I opted for the LED version so there should be no need for pin 1&2 (20 VAC Supply from J105 Pins 4&5)
I can get data and clock from J123 pins 4&5 and connect to J1 pins 5 & 6, so good there.
