So it's been about 3 months since I had my whitewater plugged in. I turned it on and it keeps resetting, usually before it gets to the end of the testing progress bar, at most a few seconds after it finishes the testing.
The only things I've done to it since last playing it is that I wheeled it across my basement, plugged it into a different outlet, and put lights in the topper for the first time. My gut says it's either coincidence or the lights blew something up.
My experience with the repair side of pins is pretty much limited to replacing a fuse, a burnt GI connector, and an opto. I did check the voltage at my outlet and inside the pin and both are a steady 123 volts. The power cord isn't loose in the back of the game. What's the next logical step? Reset all the connectors? It's humming pretty loud in the backbox, and once it screeched loud enough to wake up the neighborhood.
On a side note, are the sockets for the bulbs in the topper incredibly tight? I had a very hard time getting the bulbs in, and I actually broke off a couple sockets removing the bulbs. I just used standard 194 bulbs and they all lit up when I first turned it on. Now that I broke those sockets, I'm going to replace both of those light boards on top. Are these the recommended replacements?
https://ksarcade.net/white-water-topper-lamp-board-wh2o-tlb.html
Is there a benefit to replacing the topper light driver board too?
