(Topic ID: 269980)
Whitewater - My second restoration attempt!
By arcadenerd925
  • 87 posts
  • 18 Pinsiders participating
  • Latest reply 3 years ago by Elicash
  • Topic is favorited by 19 Pinsiders
There are 87 posts in this topic. You are on page 2 of 2.
#51 3 years ago
Quoted from mastercello:
Nice work so far, i have the same task ahead of me in the next few weeks.
But i will get a completly new cabinet with the bolts already removed (head) or immersed where ever possible?
How about the cutout of the legs on the front and side - did they line up on yours?
Mine have a little difference on them.
Mine lined up perfect. The only annoying thing was the cutout for the cab protector not fitting in the back, but it was a quick fix.
#52 3 years ago
Quoted from Soulrider911:
Nice work looking good!
Thanks! Not sure how you paint yours, but if you ever want to borrow my paint sprayer hit me up. (same goes for anyone else local)
#53 3 years ago
Quoted from Bryan_Kelly:
Thank you, Steve!
Glad they made it there safely, enjoy!
#54 3 years ago
Went around and cleaned up some edges. Here i want to make sure the front of the rail wasnt going to push against the front decal, so I trimmed a little off with the dremel.
Went to put the legs on and to me they were just too close to the rad cal. I figured they would probably rub during any nudging. Asked wifey to cut out some felt to go in between the leg and the cab protector (I did this on FH as well). They are the same shape as the protector so they wont be seen.
#55 3 years ago
Legs and cabinet armor on, looks gorgeous! 100% happy I went the candy chrome route (though expensive, ugh, but worth it)
#56 3 years ago
Next up, put the backbox/head back together and get that sucker back on the machine. But first, need to clean up and paint the bolts.
I used rustoleum for the bolts and black metal parts on my FH and thought they came out really nice so I am doing the same here.
#57 3 years ago
so what paint did you use for the final match? you showed us your choices, but i never saw the final pick. also would like to see the bits you used for the cutting of the radcals if possible. btw, looks great
#58 3 years ago
Quoted from ccbiggsoo7:
These are the bits i use: https://www.amazon.com/SE-8230DD60-30-Piece-Assorted-Diamond/dp/B001BK0TRM/ref=sr_1_1
I went with "homecoming blue" for the paint. It's not perfect, but I am really happy with how close it matches (second from the left when I was trying colors out).
#59 3 years ago
Got the back box finished and installed. Put all the boards back and wired things up! (yay, it didnt explode when I turned it on)
Next I popped in the colordmd.
#60 3 years ago
Getting ready to put the rotisserie together, but first I need to sort out the wood rails.
Looks like they are wrapped in some kind of vinyl?
I assume I peel this crap off, sand and paint them?
#61 3 years ago
one word... nope
Like when I took vynil off the cab, I tried heating it up and peeling it off. It actually came up pretty easily but what it left behind was this nasty glue residue.
I sanded it off the best I could but I was barely getting it up. Stupid me decided to just paint it. My theory.. "just put several coats on it and it will be fine"
ugh, wrong.
No matter how much I painted it, it looked terrible and was all sticky. So I sanded the paint off and you can see where the glue remains.
Feeling defeated I decided to break for the night.
#62 3 years ago
One of the handy things about living around here... 20 minute drive to Cliffy's house!
Drove over, shot the shit for a while... always enjoy a visit to Cliffy's
Managed to snag a shirt while I was there.
#63 3 years ago
Ok, back to these god damn things.. I found that sanding was doing me no favors. The heat from the sanding was melting the glue and gumming things up. I eventually figured out that a whole shit ton of elbow grease with the putty knife was the way to get this crap off.
After a good solid hour of that, followed up by some final sanding I was finally good to go.
Tomorrow I will paint these suckers (again!) and get these on the PF.
Hoping to get the rotisserie up by tomorrow night so I can start re-populating things.
#64 3 years ago
Quoted from arcadenerd925:
one word... nope
ugh, wrong.
Yeah, I hate that vinyl crap. I figure i should just use some oak scraps around and remake them, but I haven't brought myself to doing that yet.
#65 3 years ago
I just ordered nice new ones in blue from reese rails - which is doing a fabulous work!
#66 3 years ago
This is the route I will go next time, hindsight being 20/20
#67 3 years ago
Old and new side by side, I was only able to spot one miss on Mirco's part at first glance (nothing major imho). Very happy with how it looks.
Time to get this bad boy on the rotisserie
#68 3 years ago
First up, the pops. To get the screws in I took a large fender washer, put some felt on the back and then I just screw a nut on to it that will slowly bring it right into the right spot (vs hammering it in, not that there is anything wrong with that if that works for you, but it makes me cringe)
My big helper again installing the lamp sockets
Back side all done
I went with orange skirts, I like the "pop" of color it gives
#69 3 years ago
Playing a little catch up here.
Installing the mantis ramp protectors was kind of a PITA. First off, they did not fit the thickness of the PF. Rather than try to bend them though, I just routed down a bit on the back side of the wood.
For the targets, I read through other threads going over this install and the consensus seemed to be that the targets should go as far forward as they can. I just used the dremel to make some new pilot holes.
In the end, very happy with how they went in.
#70 3 years ago
At this point, just trying to wrap up getting the top-side back together.
#71 3 years ago
Disaster drop time. I had to dremel the bottom front so the flap sat flush on the playfield
20200701_143345 (resized).jpg20200701_143345 (resized).jpg20200701_150257 (resized).jpg20200701_150257 (resized).jpg
#72 3 years ago
With the bulk of the topside done (sans upper pf) time to wire things back up
#73 3 years ago
Before putting the wired up playfield back in, gotta install these mirror blades first. Super stoked as I hadn't planned in it (but wanted to) and got surprised on my bday last week.
#74 3 years ago
With the playfield back in, time to install the new boulders. A little darker than the originals but I like em.
20200705_140544 (resized).jpg20200705_140544 (resized).jpg20200707_190506 (resized).jpg20200707_190506 (resized).jpg
#75 3 years ago
A few oopses though... lol.
#76 3 years ago
Holly crap, getting the upper ramps to all fit is no small feat.. ugh
20200705_213512 (resized).jpg20200705_213512 (resized).jpg20200705_215157 (resized).jpg20200705_215157 (resized).jpg
#77 3 years ago
Getting closer
#78 3 years ago
Got the ramps in.
For the whirlpool ramp I had to route down under the flap so it would sit flush. I also had to route out more space for the diverter to move in.
#79 3 years ago
Finishing up.. a few oopses
First, wrong sign? Lol
Second, ball was getting stuck so I had to dremel a little more clearance
#80 3 years ago
And it's a wrap!
This was not an easy one. I feel for anyone that has to shop a WH20. That upper PF and upper ramps are just just beasts to deal with. Specially with repro ramps. They are gorgeous and 100% worth it, but man.. they just require a ton of tweaking and dremeling to fit.
Very happy with all the stuff I added. Mirror blades look awesome on this game. Really like the new boulders (yes darker, but still very nice IMHO). The LED's really brighten things up and compliment the artwork well. The candy chrome (and the blingy chrome door) really work well with the game (for me at least). The rad cals, my first time doing these but man, I love them. It looks like my old WOZ's clear coated cabinet, it's just a work of art.
There were certainly some struggles.. and this definitely too longer than I would have liked it to, but hey.. it's way shorter than the 7 months it took me to do my funhouse, lol.. so at least I am improving.
This game is 100% a keeper for me, so I am just super stoked to have it finally done.
20200712_085735 (resized).jpg20200712_085735 (resized).jpg20200712_085800 (resized).jpg20200712_085800 (resized).jpg20200712_085814 (resized).jpg20200712_085814 (resized).jpg20200708_180714 (resized).jpg20200708_180714 (resized).jpg20200708_080649 (resized).jpg20200708_080649 (resized).jpg
#81 3 years ago
Looks great!
#83 3 years ago
Awesome job! Anyone that takes the plunge doing a full restoring a Whitewater derservers and applaud for coming out successfully. This is one of the hardest games to restore - correctly - IMO. High Five arcadenerd925 !
#84 3 years ago
Very nice and impressive work - congratulations!
I have mine ahead and will might ask you regrarding the tweaks and dremel actions on the ramps once i'm there (if i'm allowed).
#85 3 years ago
It looks great! And I'll second the new ramps needing tweaking in places, but worth it in the end.
#86 3 years ago
Nice job!
(Recommendation: use screws for Bigfoot's cave boulder on the left side, like the original - instead of zip tie.)
#87 3 years ago
Great detail about dremeling and ramp and mantis fitting.
$ 399.00
Nezzy's Pinball Prints
$ 9.95
Mitchell Lighting
$ 5.95
Mitchell Lighting
$ 69.50
7,600
Sugarloaf, CO
$ 84.99
FlyLand Designs
12,610 (OBO)
Mapleton, UT
$ 12.95
Pinball Pimp
$ 189.00
Playfield - Plastics
Starcade Amusement
Pinball Z
$ 329.99
$ 9.95
YouBentMyWookie
$ 34.99
Rubber/Silicone
NO GOUGE PINBALL™
$ 27.95
$ 54.99
17,250 (OBO)
$ 12.95
$ 60.00
$ 1,059.00
$ 225.00
Professor Pinball
7,699 (OBO)
Evansville, IN
$ 225.00
Cabinet - (Alt) Translites
FlyLand Designs
$ 119.99
FlyLand Designs
$ 10.95
This page was printed from https://pinside.com/pinball/forum/topic/whitewater-my-second-restoration-attempt/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
