(Topic ID: 57710)
WHITEWATER CLUB= Lifejackets not required
By Skypilot
7 years ago
  • 5,802 posts
  • 515 Pinsiders participating
  • Latest reply 2 days ago by dusin1
  • Topic is favorited by 244 Pinsiders
There are 5802 posts in this topic. You are on page 61 of 117.
#3001 2 years ago
I did this yestrday before and after pictures
20180609_112830 (resized).jpg20180609_153415 (resized).jpg20180609_202434 (resized).jpg
#3002 2 years ago
This gives me the chills.
#3003 2 years ago
Looking for a nice used dome topper. LMK if you have one and price. thx
#3004 2 years ago
Quoted from kimzone:
My daughter (12yo) was looking over my shoulder as I was admiring your machine and she said, "Dad, that looks like WhiteWater only whiter and bluer and cleaner."
Well done!
I've heard some question the white mountains within the theme but these must be folks who raft in California or someplace. Here in Colorado it works perfectly as our mountains are still snow-covered during the spring run-off (the best and fastest water).
#3005 2 years ago
Were those custom painted mountains? I've seen the white ones before, but never to that detail. Even the skull head.
#3006 2 years ago
I think The Spirit of the River cast a spell on my game. In the video, I power on the game, then, after self-test, hit Start. There are vertical lines in the display and sounds are out-of-whack. Hopefully it's a just a ribbon cable, but dang...
#3007 2 years ago
Quoted from Paul_from_Gilroy:
Update: Reseating the main ribbon cable (the one with 4 connectors) fixed it.
#3008 2 years ago
Always a big relief when stuff like that ends up being an easy fix. Glad that you were able to quickly solve the problem.
#3009 2 years ago
Yeah definitely a good thing thst wasnt more serious. Last night in the middle of a game on ball 2 the game sent up diagonsl lines on my dmd and killed the game. The ball rolled down into the drain as the flipoers were dead. Then i could push start and a new game started just fine so I have no idea what the hell that was all about but hopefully not something starting to go bad.
#3010 2 years ago
Hey fellow rafters, considering a micro pf for my WH20 which is currently has original pf with some planking but doesn’t effect play.
I know ultimately it’s preference, but is it better to just keep the og DP pf intact on this title or consider a swap?
The game isn’t going anywhere.
Looks like a challenging, fun yet frustrating project but gathering some opinions before I go down this part of the river.
Thanks for any input guys
#3011 2 years ago
Quoted from Vino:
How is your pf look like? Please share some photos.
#3012 2 years ago
Quoted from Vino:
If you have a lot of spare time, monies, aren't worried aboot recouping them, and have nothing better to spend the monies on then sure. But seriously that's aboot where I stand. If you have space to add games that's a lot of coin that you can use going forward.
#3013 2 years ago
I hear that!
It might be worthwhile but the time commitment has me thinking let it be for now and save for the next trade/pin.
#3014 2 years ago
Quoted from Vino:
I hear that!
I've found there are a couple of things that make a full, ground up restoration most satisfying and rewarding: 1) You've wanted the game for a long time and you regard it as a "keeper" and 2) It's a beat-up mess when you get it.
#3015 2 years ago
Just joined the club!
Anyone holding a white boulder set they want to sell? I’d like to swap mine for the holidays... got a whole thing planned. Seasonal!
#3016 2 years ago
Looking to join the club. Reach out if interested cash or trade!
Added over 3 years ago:
TnA or afmr
#3017 2 years ago
Hey guys been working on wh20 fixing a bunch of little odds and ends. So i'm down to my last error and am completely stumped on it. I have rebuilt the damn pop bumpers completely and am still getting this error at startup. Just to be clear I had this issue also b4 idid the rebuild. It works completely fine after I reset the error in test mode and scores properly. Anyone have any insight into this issue to help me keep my sanity.
#3018 2 years ago
Quoted from PinDeLaPin:
switch to the right of the center pop. It is most likely closed all the time. Needs to be adjusted open
See manual page 2-43 for exact location
#3019 2 years ago
The manual is your friend. Get pdf copy at IPDB if you don’t have a paper version
#3020 2 years ago
#3021 2 years ago
Quoted from zene10:
Yrs I have a manual and have gone over it and rebuilt the pop bumpers and replaced the switch on each one also and am still having the problem.
Thx for the suggestion Davi will check those later on today.
#3022 2 years ago
the circled one on the top is stuck closed.
#3023 2 years ago
Quoted from Marvin:
Thk you Marvin i will definitely check it when I get home. Sure hoping thats what it is cause its driving me crazy.
#3024 2 years ago
Hi rafters!!
I'm having some issues with my 'Disaster Drop' shot. If I test the entry optos with the glass off it works ok, rolling a ball through slowly is fine. But during a game it seems to be hit and miss.
I was just wondering, do failing optos sometimes have a problem where they can't detect fast shots?
Cheers.
#3025 2 years ago
The 2 circled switches are not polled like normal switches. When they put in the rubber between the pops to stop outlane drains they took them out of the "not hit in X" credit dot. If there is a dot for those two switches it would have to be a stuck closed situation. check the diagnostices for closed switched, then adjust afterward.
#3026 2 years ago
thewool, if I recall correctly, that ramp opto entry can be finicky because the optos are positioned on the outside of the ramp. It could be as simple as having to pull the ramp and clean it so that the optos have a clear shot through the plastic.
#3027 2 years ago
Quoted from mbaumle:
You're right this is through a ramp, it was working correctly so maybe it's just got a bit dusty. I'll give it all a clean and see if this sorts it.
Thank you.
#3028 2 years ago
Quoted from Marvin:
Ok Marvin u a bad dude! Got home and checked it out and u sir called it spot on. I didn't realize there were switches under that mountain plastic was thinking it was referring switch 55 to the right pop bumper. Sure enough i took that plastic off and that switch was definitely closed.Thk u!
#3029 2 years ago
As zene10 predicted.
#3030 2 years ago
try taking out that ring. game play is quite different. it was added since there was a lot of pops to right outlane issues but in my experience that's not a huge issue. its a balancing act. get some nice inlane feeds with it out, a few outlanes losses, a few points off those 2 switched and less pop action. or leave the rubber in, get no outlane losses, no inlane feeds, no scoring on those small scoring switches, but better pop action.
#3031 2 years ago
Scrolling thru eBay saw this Topper chrome??
ebay.com link: WHITEWATER Pinball Machine TOPPER CHROME Decal LICENSED
Where is this stuff suppose to go? Or is it a mod?
#3032 2 years ago
Sorry if it wasn't clear. Wasn't near computer to upload manual's switch map & working off my memory.
Your trouble shooting menu was indicating switch 55, not your pops (switches 16, 17, 18).
#3033 2 years ago
Quoted from flipordie:
ebay.com link » Whitewater Pinball Machine Topper Chrome Decal Licensed
There is a reflective sheet on the top of backbox, below topper lamps. However, this ebay stuff looks too short.
#3034 2 years ago
Quoted from zene10:
Yep sorry for forgetting bout your initial advice as well zene10. It was right on as well. My own fault for not looking in manual at switch layout diagram. Saw the error and immediately in my head made the assumption it was saying right pop. I guess we all know what happens when u assume right?
#3037 2 years ago
So all of a sudden I got the infamous bigfoot error last night. Looked at my bi-directional board and the led would light intermittently. After I looked at the board I determined the cap had started to leak. Question is can I replace the 35v 100uf cap with a 50v 100uf one? I only have the 50v ones on hand and wasnt sure it would make matters worse if i installed it. Any feedback would be great on this thx.
#3038 2 years ago
20180729_132659 (resized).jpg20180729_132737 (resized).jpg20180729_132854 (resized).jpg
#3039 2 years ago
Sure you can replace. Higher voltage rating is not an issue.
http://www.learningaboutelectronics.com/Articles/What-does-the-voltage-rating-on-a-capacitor-mean
#3040 2 years ago
Ok cool good to know thank you Davi.
#3041 2 years ago
Howdy WH2O fans,
Would any of you fine pinheads mind helping me a little with a flasher position issue I have found myself in.
Backstory
Helping a mate out with a WH2O that he bought as a project, playfield was completely stripped by the previous owner and over the course of many years pieced back together. I have corrected the numerous wire hacks, missing molex connectors and wrong wiring orientations ( yes some molex connectors were missing the keyed plugs, who would have guessed?)
The issue I have is the manual doesn't really indicate where all the flashers are around/under the mini playfield.
SOL23 blue/gray
SOL24 blue/violet
A photo or two would be very useful. Thanks in advance.
#3042 2 years ago
Quoted from centre-drain:
Howdy WH2O fans,
Backstory
SOL23 blue/gray
SOL24 blue/violet
Here are the locations in my game...
#3043 2 years ago
Here are the locations in my game...[quoted image][quoted image]
Firstly Paul let me say a massive thanks for getting back so fast and an "A" for effort with the images. I really appreciate it.
They are pretty much where I guessed they may have been, I was mostly unsure about the "cave" flasher as it is already populated with
SOL17 black/brown (bigfoot head flasher).
Now this one has me stumped, I cant see any screw holes for this and it appears to be coming from the back-board direction, with enough length to mount where the cave flasher is.
#3044 2 years ago
Im in desperate need of the spotlight bigfoot mod... where it comes on when he turns! Any1 kno where i can get it?
Or can i buy the always on one and hook it up to the bigfoot motor?
#3045 2 years ago
Quoted from Dantesmark:
Want one as well...
#3046 2 years ago
Judge Dreads Pinball on eBay does them I think. UK based though
#3047 2 years ago
The always on version yes.
#3048 2 years ago
Hey guys. Has a completed custom pinsound package been released by anyone in the community yet? I've been following this thread by Endprodukt (https://pinside.com/pinball/forum/topic/white-water-reorchestration-for-pinsound-and-warren-davis ) but doesn't look like its done quite yet. I seem to remember another option available that may have been completed. Would appreciate any download links if there is anything out there. Thanks! -- Craig
#3049 2 years ago
I have a couple of burned out bulbs in the topper. Thinking I read a post about those bulbs being special ones. Anyone have a link to where I can get spares?
#3050 2 years ago
Quoted from Blitzburgh99:
https://www.marcospecialties.com/pinball-parts/04-0194
