(Topic ID: 57710)
WHITEWATER CLUB= Lifejackets not required
By Skypilot
9 years ago
  • 7,082 posts
  • 579 Pinsiders participating
  • Latest reply 2 hours ago by zene10
  • Topic is favorited by 273 Pinsiders
There are 7,082 posts in this topic. You are on page 142 of 142.
#7051 9 days ago
Quoted from woody76:
Yep, I opened in AI and PS and it needs to be sized. Still a solid image so should work. Thank you
Let me know if you need the original scan.
#7052 9 days ago
I have a spare "big foot cave" plastic if anyone needs...DM me.
#7053 8 days ago
Looking for a White Yeti for a customer that is going the white look on White Water. PM if you have one, Thanks
#7054 8 days ago
Quoted from firefighter:
I don't have one, but I would but the non white arms off of your customer somehow, mine are missing!
#7055 8 days ago
Quoted from Pinkitten:
Congrats on your game! A good topside tear down (take lots of pictures!), cleaning and waxing is a great start. WH2O is a pin you can easily spend $2-3k quickly on rehab, but it’s also SO tempting to restore this pin. All the boulders can be replaced with new (so they match), ramps, plastics, etc. I would suggest replacing all your rubber rings with either a kit, or buy a couple boxes of assorted clear rings from Pinball Life (easier for people here in the states). Install new pop bumper caps (I like the transparent blue), and order new correct standup targets as depicted in the photos above by Zartan. You can get the 2 green ones for the lite/lock targets, 5 blue for RIVER, 2 white for hot foot, 3 red for lite kickback, and one amber for extra ball. It’s expensive, but even the cleaning, wax and rubber rings will really help. Good luck and have fun! Post before-after pics.
Thank you for all your advices.
Today I have clean the all the playfield and parts.
And also replace all rubber rings and all the dead lamps.
That' really better.
I have a question: how does the knocker works ?
On mine, it was working but it doesn't work anymore since few hours.
The solenoid test is ok, so I don't understand...
All the game is ok, except the knocker
EDIT : Problem solved. The knocker works only if replay is set with "credit".
Knocker doesn't work if replay is set with extraball.
#7057 8 days ago
Quoted from Davi:
I have this scan.[quoted image]
This is great! Thank you very much!
#7058 6 days ago
I'm sure a bunch of guys here have installed the PinSound setups on their machines. I'm not interested in the additional speech downloads but I am interested in better speaker quality. My question is, will I get a noticeable difference with just adding their speakers? I'm sure adding the Plus sound board provides greater adjustments to the speaker levels. I'm just trying to figure out if it's worth buying the Plus sound board because it will enhance the speaker quality even further.
#7059 6 days ago
Quoted from G35R6:
I’d recommend it. I purchased and don’t regret it one bit. Thought the sound was much better and I enjoy the ability to toggle between a few sound packages.
#7060 6 days ago
If anyone can use this let me know. It the remake that does not work very well but it is better than nothing. If you lean it forward the waterfall effect is decent.
#7061 5 days ago
Is that the Twisted Pins remake?
Gord
#7062 5 days ago
Anyone try precision flippers on this title yet? I Kaiser ordered a set of the halo-whatchamacallit-version. Looking forward to trying them out.
#7063 5 days ago
Quoted from shokel328:
I haven't tried them on this title, but did on TZ. They were too powerful for that game and I ended up using weaker coils to compensate. I think you'll have the same problem here.
#7064 5 days ago
Quoted from daveyvandy:
I'm curious if an LED OCD board could smooth those out?
Nope
#7065 4 days ago
Quoted from GRB1959:
Gord
Yep, I purchased a really cheap WH2O a while back that did not have a topper. I recently found a original topper and seeing if anyone can use this one.
#7066 4 days ago
I completely understand, I have a really nice like new topper on my WH2O as I was able to find an NOS white plastic standup, clear plastic dome and an NOS topper decal back in 2009. I also purchased one of the Twisted pins WH2O toppers back in 2013 that is now stored in my pinball parts stash.
Here is a video of my WH2O topper in action.
I agree that if someone is missing a topper on their WH2O that the TP topper is much better than not having one. Unfortunately the foil embossing on the TP topper wasn't deep enough for the waterfall effect to work like it does on the original WH2O toppers.
Gord
#7067 4 days ago
I agree that if someone is missing a topper on their WH2O that the TP topper is much better than not having one. Unfortunately the foil embossing on the TP topper wasn't deep enough for the waterfall effect to work like the original WH2O toppers.
Gord
Seeing that video makes me wonder if my topper bulbs are too dim. Are you using leds?
Yours look very bright so perhaps it’s the camera angle. I recently replaced all 16 with brand new, CEC #194 bulbs.
#7068 4 days ago
Quoted from EEE:
No LED's for me in the topper. I tried some about 12-13 years ago and it significantly reduced the waterfall effect. The prior topper video is from 2018 so I created another video a few minutes ago and it is posted in this reply.
I am taking the video from the front of the pinball machine holding the camera up high so it captures the entirely of the topper lights and the waterfall effect.
Gord
#7069 4 days ago
Gord
That's some nice white 194 incandescents there. I like it! Any idea of the brand or model #? Most all 194 incandescents I find are that awful yellowish color. I switched to LEDs just because I couldn't find a nice white incandescent.
#7070 4 days ago
Quoted from CoolCatPinball:
I am pretty sure that I purchased most of my spare incandescent bulbs from Pinball Life. I looked at my parts stash just now and the #194 bulbs are all the Eiko brand.
Gord
#7071 4 days ago
Gord
Shopping for those Eiko bulbs now
#7072 4 days ago
It's probably the camera auto adjusting the white balance, making it look more white. Same with EEE's photo of him thinking his bulbs are too dim. Those look like LEDs in the translite, and the camera is compensating the brightness by making the topper look dimmer than it does with the naked eye. If you take a photo of just the topper does it look brighter?
#7073 3 days ago
Anybody have the full instructions for the hotfoot and Bigfoot spotlight mod? Just picked up a WW with both uninstalled in the box and I can’t seem to find the instructions anywhere online. Thanks!
#7074 3 days ago
Quoted from dddanielll:
https://drive.google.com/file/d/1AP5QAPwN1Ln5hSyhZiFcyw3cV68Gd-a8/view?usp=sharing
#7076 1 day ago
I just joined the club on Monday and I think I may have something pretty interesting! My friend that I bought this machine from said that he's the second owner; the first owner alleged to have bought the machine at a trade show when it first came out, making it an early sample game running a pre-production ROM. I went ahead and ordered the LH6C ROM so I could get the benefit of the various bug fixes. Once I got the machine home, I was intrigued to see that the ROM version it's running is P-6. I've scoured the internet, but I can't even find a reference to this particular ROM version; the earliest ROM listed on IPDB is P-8, which I'm assuming was the last pre-production ROM. Has anyone else seen a White Water running P-6? I doubt there's anything revolutionary about it -- it seems to have all the same features and glitches of the early ROM versions -- but it may be worth documenting.
#7077 1 day ago
I had a couple of translucent yellow stand up targets in the parts bin and I’m considering swapping them in place of the original white ones for Bigfoot Hotfoot.
Any thoughts on whether this look good, better or horrible? Pictures aren’t great and make the area look dark.
If they stay I will add some illumination behind them and I might swap out the yellow post sleeves for blue or white or _?
3F1A6AA2-439D-4B6A-A7C0-40BF5350646A (resized).jpegAAF0B6E5-A687-4FFF-818C-C126CD0DE4C1 (resized).jpeg
#7078 1 day ago
Quoted from EEE:
If they stay I will add some illumination behind them and I might swap out the yellow post sleeves for blue or white or ?
[quoted image][quoted image]
I don't think there's anything wrong with that. Would definitely look better with some back lighting.
#7079 23 hours ago
I just got my new mountain set from Starship Fantasy. They look awesome!
They seem alot thicker than the original. Are they able to withstand an air ball?
#7080 23 hours ago
Quoted from EEE:
I like them better than the white targets. Blue post sleeves would be perfect I think.
#7081 21 hours ago
Quoted from EEE:
Those yellow translucent look great, very consistent with the blue and green. The white look fine, but I prefer your yellow.
#7082 2 hours ago
You can contact me directly and I’ll send you a link. Same with installation questions.
$ 69.99
Pinball Shark
Shooter rods
Slap Save Creations
$ 69.50
