(Topic ID: 57710)
WHITEWATER CLUB= Lifejackets not required
By Skypilot
10 years ago
  • 7,832 posts
  • 630 Pinsiders participating
  • Latest reply 33 hours ago by lrosent345
  • Topic is favorited by 299 Pinsiders
White Water 12-7043 Wire.pdf (PDF preview)
There are 7,832 posts in this topic. You are on page 105 of 157.
#5201 3 years ago
Quoted from woody76:
order a repro from pin-pimp. Already comes mounted on plastic. Just need the dome. If you mount the repro with spacers in the back and let it lean forward you get the waterfall effect of the original. I picked one up cheap a while back with no topper as well.
is that the "TwistedPins" reproduction? I heard that wasn't a popular solution. Unless this is different. How much did it cost you?
#5202 3 years ago
Quoted from McSquid:
Yes, but looks way better than glitter solution. I have had friends play mine and they can't tell its a reproduction. You have to angle it forward and the effect is pretty darn close to original. I can't remember what I paid.
#5203 3 years ago
Ok if I can get ahold of him I'll consider it. It's not listed on his website.
#5204 3 years ago
I agree, it's better than nothing. But to call it pretty close to original? Based on feedbacks and videos it's far away. The waterfall effect is missing.
https://www.google.com/amp/s/creditdotpinball.com/2014/05/22/mods-foiled-again-the-white-water-topper-reproduction/amp/
#5205 3 years ago
Quoted from Davi:
Can you read? You have to mount it differently. It has to be mounted with spacers so the entire thing leans forward. It is not perfect but way better than glitter and so far no one has even noticed it was a repro
#5206 3 years ago
Have any of those people ever seen a real one in person and do those people have decent eye sight? I've seen the setup you have / are referring to and it took me roughly one second to see it wasn't an OG. May be the best alternative out there but it's still a far cry from the original one - pretty amazing that in 2020 we can't find a way to reproduce that thing.
#5207 3 years ago
Don't be upset. I know what you mean. The link I posted contains a video comparison between original and tilted repro. Day and night.
#5208 3 years ago
Quoted from Davi:
mine looks better. spent hours adjusting the stupid thing. There are not any alternatives so it is what it is, but much better than glitter. When you get a white water for $2500 it is hard to argue.
#5209 3 years ago
Quoted from bobukcat:
I have a printing company and I took a spare original I used to have we tried to replicate it. I spent hours researching what the original artist did and we decided it was not worth the risk to try to reproduce. The guy that did the original work past away around 3 years ago. I personally do not think it will ever be redone. The guy overseas that is doing all the work by hand might have so me luck producing 1 piece but I do not think it will ever be mass produced again.
#5210 3 years ago
Quoted from Davi:
I just watched that video and there is NO waterfall effect. Mine has actual effect. You have to adjust it just right. I have owned several white waters and my wife still does not know it is a repro.
#5211 3 years ago
I have the skull mountain mod from Andy over in the U.K., and I’m having some trouble knowing where to connect it.
If I’m not mistaken, can’t it be connected in a way so that it stays lit when the lock is lit? If so, where should I connect it? I know that a gi connection keeps it on always, and when I connected it to the flasher from the left mountain it only flashes when the green “Lite” or “Lock“ targets are hit. It doesn’t stay lit after both targets are hit. I’ve looked through this thread and couldn’t find an answer, so I welcome any thoughts or guidance here.
Thanks so much.
#5212 3 years ago
Quoted from eb94114:
Thanks so much.
Yes, I installed this recently. The instructions that came with were a little misleading. You actually want to plug it into the flasher that is located in the very back right of the machine (The dome one that is on the mountain). Then when you lock a ball, the eyes will blink fast in synchronization with that flasher. The eyes will only be on when the flasher is going.
#5213 3 years ago
Quoted from boustrophedonic:
Replace C2 electrolytic on the motor control board if not done already (just had mine fail). Cliffy on upper playfield ball drop.
Checked mine out while inspecting everything. Mine has a red PCB. Possible the board has already been replaced? I've only been able to find pics of this board having a green pcb.
#5214 3 years ago
Red PCB generally were used for prototypes or sample games AFAIK.
#5215 3 years ago
Quoted from daveyvandy:
Thanks for letting me know. So if I understand correctly, the eyes will flash only when “lite” and “lock” are hit? Does it also flash when the ball is locked? Is that when that flasher you connect to flashes?
Also, while trying to patch this in, the small molex connector on the mod, the one that has a red wire and two black ground wires in it, had one black and one red wire break off. It looks like they need to be repinned. Any suggestions on how to get the old pins out of the connector?
Thanks again.
#5216 3 years ago
Thanks again.
By tapping into the flasher, it will go off whenever the flasher goes. I'm not sure off the top of my head, but I know for sure when you lock a ball it goes crazy.
Got any pictures of the break? You may not need to repin if you can use something like a butt splice.
#5217 3 years ago
It's a 5 minute job to replace and from what I have seen these fail frequently. It was a smelly mess and I had to replace a fuse as well as the traces that were eaten away by the electrolyte.
#5218 3 years ago
I am interested in buying a White Water that is in rough shape, somewhat local around my area for pickup (Sacramento CA). If someone has one and is interested in parting ways with one, PM me!
#5219 3 years ago
I had a twisted Pins topper, decided to just to stay with my slightly bubbled original. The waterfall effect was no where near the original. The texture on the Twisted Pins is just not as deep... thus the effect just is not there. However, its better than nothing for sure. Here is a video Ill leave it up to you all to judge
#5220 3 years ago
Quoted from Soulrider911:
I had a twisted Pins topper, decided to just to with my slightly bullbed original the waterfall effect was no where near the original. The texture on the Twisted Pins is just not as deep... thus the effect just is not there. However, its better than nothing for sure. Here is a video Ill leave it up to you all to judge
I would buy your original if you decide to go with the twisted pin.
Cash ready to go if there is one available from anywhere
#5221 3 years ago
Soulrider911... to me it's a close call.
The original definitely has much more water fall movement, however, the huge crease down the center and the faded looking mountains brings it way down... with that said; the repop has nice mountain colors, it's clean and new looking but the flashlight is really lacking.
I would put it up with the 194's lights blinking on both, then decide. I'd be slightly leaning towards the repop.
Kerry
#5222 3 years ago
Quoted from Kerry_Richard:
Kerry
Don't do it man, you'll be sorry!
#5223 3 years ago
Anyone have a spare orbit metal ball guide? The really long one? I'm tearing my WH20 down and realized this is the only metal guide Ive ever seen that is long enough to work with my home-brew game (Sonic the Hedgehog) Cant find it for sale anywhere.
#5224 3 years ago
All naked
#5225 3 years ago
All naked
sexy
#5226 3 years ago
Mylar+glue removed. Scrubbed clean.
FJIMG_20200906_170947 (resized).jpgFJIMG_20200906_170947 (resized).jpgFJIMG_20200906_171005 (resized).jpgFJIMG_20200906_171005 (resized).jpg
#5227 3 years ago
Cleaning out some spare parts and found a bumble figure I never ended up using with my white mountains. If anyone wants it just shoot me a PM, you can have it for $20 shipped locally.
20200913_132007 (resized).jpg20200913_132007 (resized).jpg20200913_132115 (resized).jpg20200913_132115 (resized).jpg
#5228 3 years ago
Bumble is on its way to a new home
I've also found some used plastics that came off mine with a few new pieces in there as well. $30 plus first class postage.
Bag on the left, blue on the top, and the clear piece in the bag at the bottom are the new pieces.
Edit: also found a 7pc ramp decal set which is just minus the little sticker for the complete 8pc set. $35 plus shipping
#5229 3 years ago
Adding Titan superior fluted LEDs to my game. The difference is astounding. New on the left, dimmer bullet dome LEDs on the right.
DSC_1221 (resized).JPGDSC_1221 (resized).JPGDSC_1222 (resized).JPGDSC_1222 (resized).JPGDSC_1223 (resized).JPGDSC_1223 (resized).JPG
Put one of these in the left bumper with single SMD bulbs in the others on the right. Really helps light up the Boulder Garden!
#5230 3 years ago
Quoted from Crash:
Might have to try them myself in the boulder garden area as well. I have always hated how dark it is over there.
#5231 3 years ago
I have a spare boulder if anyone is interested.
$30 plus shipping.
Pm me if interested.
This is from PPS website 3 years ago. Not the Newer darker version.
Added over 3 years ago:
Sold long ago.
#5232 3 years ago
Touched up and clearcoated. Once it's done curing we shall see if it needs sanding/polishing
FJIMG_20200919_234732 (resized).jpgFJIMG_20200919_234732 (resized).jpgFJIMG_20200919_234746 (resized).jpgFJIMG_20200919_234746 (resized).jpgFJIMG_20200919_234755 (resized).jpgFJIMG_20200919_234755 (resized).jpg
#5233 3 years ago
I really need to find one of the protectors for the Big Foot Bluff shot (This post shows one, so apparently they exist, but it's not a Cliffy: https://pinside.com/pinball/forum/topic/whitewater-club-lifejackets-not-required/page/98#post-5642459). The Scigrip repair held this piece of plastic in place for a few months, but then a *new* crack formed along the bottom and it just now fell out again. If I keep just using Scigrip this piece will eventually shatter into a bunch of tiny pieces.
I did replace the flipper coil with the correct strength a few months ago, so it's not that it's too powerful or anything.
#5234 3 years ago
Quoted from mystman12:
Why not make your own? It's a simple plastic hidden by the mountains so it can look as ugly as you want.
I made one myself from a translucent scrap plastic I had and it works great in protecting the switch further up.
#5235 3 years ago
Quoted from Lhyrgoif:
I made one myself from a translucent scrap plastic I had and it works great in protecting the switch further up.[quoted image]
Actually I'm not talking about the switch, I've already protected that. I'm talking about the cracking at beginning of the first turn on the ramp. You can see in my pic that it's cracked so bad there's now a hole on the side. The metal piece over that spot in your photo is what I'm looking for.
#5236 3 years ago
Looks like that metal piece is from Disaster Drop ramp entrance.
Buy a Disaster Drop ramp protector from Cliffy, and move the original metal piece to Big Foot ramp.
http://www.passionforpinball.com/WH20/wh20cliffy_vs_oem.jpg
http://www.passionforpinball.com/wh20.htm
#5237 3 years ago
Quoted from Davi:
That's the answer I was looking for, thanks! I think my game already has the cliffy installed, but the guy I bought the game from included all the original ramps, and I found a different metal guide that should work just as well!
#5238 3 years ago
Mod overboard?
920ABFAD-CD4A-48C4-9031-826D8B88FF94 (resized).jpeg920ABFAD-CD4A-48C4-9031-826D8B88FF94 (resized).jpeg
#5239 3 years ago
Quoted from etien:
Mod overboard?[quoted image]
Yup.
#5240 3 years ago
Quoted from etien:
Oh boy, that's just ugly. So many rafts, animals and other crap, its closer to a toystore than a pin. Ewwwwww.
#5241 3 years ago
Quoted from etien:
Man...overboard.
#5242 3 years ago
I knew you would like it
#5243 3 years ago
I like the waterfall and no way out skull mod... the rest... eh.
#5244 3 years ago
That's an expedition amount of rafts! Man Overboard for sure!
#5245 3 years ago
Hah, i like the rafts.... the rest eh.
#5246 3 years ago
As per @davi's suggestion, I found an old metal guide and cut and shaped it to fit the Bigfoot Bluff ramp. After repairing the plastic with some Scirgrip 3 (This time I managed to do a better job applying it than in previous attempts too), I put the guide in place. It slows the ball down a little bit as it passes through, but not enough to negatively impact gameplay, so this fix seems solid!
#5247 3 years ago
I've got a new set of boulders/mountains for sale, if anyone is interested.
https://pinside.com/pinball/forum/topic/fs-wh2o-repro-boulder-set
#5249 3 years ago
Hey everyone, just trying to clear up a few nagging issues from my White Water playfield swap/rebuild awhile back. When I perform the single switch test, "Always Closed" shows as open. Anyone know what this switch is for, why it would show open and how to resolve it?
#5250 3 years ago
I have recently been trying to do more work on my game and not have techs do it for me. That said, I am still learning a lot, and I am getting the message: "Check Switch 54/Lower Jet Area" on the test report with a credit dot coming up. Any direction on how to go about doing that and fixing it? Thanks in advance from a very not-technical pinsider.
$ 225.00
Professor Pinball
$ 1,059.00
YouBentMyWookie
$ 9.95
$ 329.99
$ 60.00
$ 34.99
Rubber/Silicone
NO GOUGE PINBALL™
Nezzy's Pinball Prints
$ 12.95
$ 225.00
Cabinet - (Alt) Translites
FlyLand Designs
$ 119.99
FlyLand Designs
$ 10.95
7,699 (OBO)
Evansville, IN
$ 40.00
$ 84.99
FlyLand Designs
$ 27.95
$ 12.95
Pinball Pimp
Pinball Z
$ 9.95
Mitchell Lighting
$ 5.95
Mitchell Lighting
$ 189.00
Playfield - Plastics
Starcade Amusement
7,600
Sugarloaf, CO
$ 69.50
7,400
Castle Rock, CO
$ 399.00
7,800 (OBO)
Cincinnati, OH
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/whitewater-club-lifejackets-not-required/page/105 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
