Hi all,
Wondering if anyone can help me with an issue I'm experiencing on my Whitewater table. There seems to be a bit of a gap where the main ramp (the one that links the upper playfield and main playfield) joins the upper playfield at the back of the machine just behind bigfoot. At least a handful of games every session the ball will get stuck there if it is launched with just the right power and it takes some shifting.
I'm not sure if this gap is meant to be like this or whether this is just my table.
Anyway I'm wondering if anyone else has had this problem and if anyone has any suggestions that might prevent this from happening in future.
Obviously anything done needs to be reversible if I need to remove the ramps at any point and it is a pain to get at without taking all of the ramps off. I've tried putting some tape across the join but that doesn't seem to make much difference and I want to avoid anything that might affect the balls travel.
Also as a side note the kickback on the left drain lane seems to be very temperamental. It hardly ever works when the machine is first turned on but often starts working at a random point after a while of play almost like it has to warm up and then it works fine until turned off again. Initially it just won't fire at all. It works every time in test mode although it often seems to fire forward and then not retract, bizarrely when this happens it stays extended until the left flipper is pressed when it retracts ready to fire again. The roll over switch before it detects the ball fine every time.
Thanks in advance for any advice or tips.
