I have two of the 'souped up' LOTR flipper coils installed.
A few days ago, the right flipper quit. The fuse was blown. I installed a new fuse and the flipper locked up.
Installed a IRL540 in place of the 20N10L
Turned it on and the right flipper fluttered. Pressed the flipper button a few times. Then it locked up.
I expect the new MOSFET blew too.
Is this a problem with the coil? Diode?
Looking for suggestions before digging in.
The EOS switch opens.
https://groups.google.com/forum/#!topic/rec.games.pinball/O3-z3GR-eeQ
Unfortunately, no solution is documented.
I checked continuity on the MOSFET before powering up. It all looked OK.
With J9 disconnected, both coils test at about 3 ohms.
Only way to check the diode is to remove it. Will do that tomorrow.
And this is of little help.
https://pinside.com/pinball/forum/topic/rct-shorted-q16-transistor
https://pinside.com/pinball/forum/topic/lotr-right-flipper-pain
http://www.pinballrevolution.com/threads/7-stern-lord-of-the-rings.1695/
