Hey hoping something simple..ball isn't regestring when drains?
It sits in the gully until machine does a ball search and then it gets fired into position and is ok?
Is it a matter of a simple switch/sensor fault in there?
probably.. remove the apron, check balls in the trough, go in switch test and see if they all register, ..
Quoted from dangermouse007:Hey hoping something simple..ball isn't regestring when drains?
you got it, go into test mode, single switch, then hit that switch ( should be #15 Outhole) to see if it is registering. 99.9% it isn't.
If not then call whom ever you get your parts from, PBR, BAA.... etc and order part number 5647-12133-12
This page was printed from https://pinside.com/pinball/forum/topic/white-water-tech-help-please and we tried optimising it for printing. Some page elements may have been deliberately hidden.
