(Topic ID: 310176)
White Water playfield touch up and cabinet restore 2022
By Flipper_McGavin
1 year ago
#1 1 year ago
Hand painted and airbrushed.
Someone touched up the spot in the photo below, probably a long time ago because the design is different??? Maybe the touch up was done before the internet became a big thing, and was difficult to find photos of playfields. But the color matching looked good whoever did it. I removed the mylar and repainted it.
Clear coated and waiting to cure some before wet sanding. Dripped a lot of clear onto the mini playfield to level the severe valleys:
Glitter added to the visible water areas of the playfield. There are two different color tones in the water, so I used two different glitters that closely matched the two playfield colors:
Video to better show the glitter:
Cabinet restore next. STAY TUNED.
#2 1 year ago
This is really cool. Nice work!
#3 1 year ago
Looking good!
#4 1 year ago
Wonderful job! Now do mine too please.
#5 1 year ago
This is absolutely amazing work. I love it!
#6 1 year ago
Wow, fantastic job Flipper!
#8 1 year ago
incredible work, let me know when you can fix my balrog wear spot on my lotr. lol. killer job.
#9 1 year ago
Do you mind giving details as to what stage and how you place the glitter?
#10 1 year ago
I use only extra fine or ultra fine glitter, and mix it with Aleene's Clear Gel Tacky Glue. This glue dries very clear and is unnoticeable under a clear coat. You can play with the glitter:glue ratio depending on how much glitter you want on the surface, and you'll know when you added too much glitter to the glue as it'll lose its viscosity. The glue also dissolves easily with water if you mess up in an area.
I use a toothpick to apply the glue/glitter mixture onto the playfield, and drag and dab over the meticulous areas. The glitter will look a little hazy and irregularly shaped and underwhelming when first applied. Afterwards, I lightly use steel wool over the glittered areas and then clear coat the entire playfield with 2 cans of Spraymax 2K, going heavy in the areas with glitter. The glitter will really pop and glisten once the clear coat is applied. When wet sanding that clear coat, once you begin to see a few flakes of glitter on your sandpaper thats when you know when to stop sanding the glittered areas.
I then used 2 additional cans of Spraymax for the entire playfield, spraying heavy into the glittered areas. I just now finished wetsanding again, and now enough clear is built up above the glittered areas where it is a perfectly smooth surface.
$ 60.00
Decals
9,300
San Jose, CA
$ 179.95
PinSound
This page was printed from https://pinside.com/pinball/forum/topic/white-water-playfield-touch-up-amp-cabinet-restore-2022 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
