(Topic ID: 109210)
White Water High Voltage Coin Door Switch Not Working
By alchy999
9 years ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 9 years ago by alchy999
#1 9 years ago
OK as title says. When I open the coin door the low voltage does not activate. Infact nothing happens.
Things I have tested and tried so far.
joined wires together green/red and White/red and nothing to exclude a faulty switch.
Checked the wpc coin interface board for dry joints, tested the diodes and continuity all ok.
Checked wires from wpc coin interface to wpc CPU board via continuity. ok
Further reading the manual it says u20 pin 17 handles the coin door low voltage switch. I doubt it's a faulty u20 or a row or column would be out. I guess maybe a resistor or diode going from the connector to the u20 chip maybe faulty?
I have not tested from the connector J209 Pin 2 and J207 pin2 to the u20 pin 17 chip.
Before I go any further maybe some of you could give me some ideas.
Thanks for the help in advance.
Kindest regards David
#2 9 years ago
What issue exactly are you trying to resolve?
The switch you are describing is the "memory protect" switch, which has nothing to do with cutting off the low voltage (18V/50V) supply. Starting about mid-way through the Twilight Zone production run Williams added a second switch mounted on the same bracket as the memory protect switch; the second switch is wired in series with the 18V and 50V supply from the transformer, and disconnects those circuits when the coin door is open.
#3 9 years ago
Thanks for the quick reply.
That explains it all. What function does the memory protect switch have and how can you test it's working. Also does it matter which way the wires go seeing it's just a switch?
Thanks again.
Regards David
#4 9 years ago
I believe the memory protect switch disables changes to the game settings while the coin door is closed (to prevent someone from manipulating the adjustment push buttons). If the switch only has two lugs - all the originals do - it doesn't matter which wire is connected to a specific terminal.
If you use the diagnostics test T.1 you should see an indication of change when you open and close the coin door.
#5 9 years ago
Thanks Jadziedzic for the easy to understand answer.
Regards David
Nezzy's Pinball Prints
Pinball Z
$ 9.95
Mitchell Lighting
6,500
Montpelier, VA
$ 27.95
$ 399.00
$ 10.95
$ 34.99
Rubber/Silicone
NO GOUGE PINBALL™
YouBentMyWookie
$ 189.00
Playfield - Plastics
Starcade Amusement
$ 9.95
$ 219.00
Lit Frames
$ 119.99
Cabinet - (Alt) Translites
FlyLand Designs
$ 5.95
Mitchell Lighting
$ 60.00
$ 12.95
Pinball Pimp
17,250 (OBO)
$ 84.99
FlyLand Designs
$ 225.00
FlyLand Designs
15,000
Ontario, CA
$ 329.99
$ 12.95
$ 1,059.00
7,400
Castle Rock, CO
$ 225.00
Professor Pinball
$ 69.50
This page was printed from https://pinside.com/pinball/forum/topic/white-water-high-voltage-coin-door-switch-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
