(Topic ID: 318969)
White Water: Fuse 601 blowing for DMD
By Flipper_McGavin
1 year ago
  • 13 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by DumbAss
#1 1 year ago
I have a DMD controller board that has so far blown several fuses. This machine was working correctly before I did an entire teardown restore. I swapped controller boards from another machine and I got White Water working correctly, so I narrowed it down to something wrong with this specific board. I'm not sure what to test specifically, but I tested the BR1 and BR2 chips and they are within the correct .5-.7 volt range.
Wondering if cleaning the board with distilled water in an ultrasonic cleaner probably loosened something? I didn't do the hack on the back of the board, not sure what that was for.
#2 1 year ago
I wouldn't worry about the cleaning.
Power supply failures for the DMD are so common that I have a whole box of components to repair this problem.
If you don't want to go through the component level repair, I like this solution from Pinball Life:
https://www.pinballlife.com/williamsbally-dmd-high-power-replacement-board.html
If you DO want to go through the component repair, there used to be a few places you could get a kit of the parts you need, but all I'm finding now is:
ebay.com link: itm
Which has more than two weeks potential shipping delay.
If you are inexperienced in this kind of repair, put in all the parts. Don't try to replace parts only in the one section where you find a problem, this is a common mistake. You replace a part or six that you find are bad, and then you plug it in and blow up the parts you just put in. Then you'll need another kit to do the repair! It's a whole lot easier to just put in all the parts that come with the kit.
#3 1 year ago
I found a rebuild kit at Marcospecialties
https://www.marcospecialties.com/pinball-parts/WPC-SEMIHV
I watched some videos where people replace those two big blue capacitors, but these kits don't include them so I assume they don't need replaced.
#4 1 year ago
My guess is a bad bridge BR1 on that board even though you said it tested fine.
#5 1 year ago
Tonight I can try swapping the BR1 chip from the good board and see if I can get this working solely from that.
#6 1 year ago
Quoted from PinRetail:
I had a Whitewater that had a snowy display, so I went to Marco and ordered the kit for 17 bucks. I read on their site it takes about 20 minutes to replace the parts. Must be a typo, they missed adding a 1 in front of the 20. So I replace the parts and each component was neatly labeled in a tiny bag. Last component to go in was MJE15031 (Q6) as the bag was labeled. Out of habit I looked at the actual transistor. It was a MJE15030. Luckily, I had bought 2 kits because we have many WPC's as a back up. In that kit, the same wrong transistor in the correct bag. So I alerted Marco of the wrong part in right bag and they said they would check their inventory.
Once the correct transistor came in, I installed, fired it up and the snow effect was gone. One thing I did do was to really get the power resistors away from the board and use heat shrink on the wire ends to prevent shorting.
#7 1 year ago
Quoted from Seamlesswall:
^^^ THIS ^^^
The heat damage to the board substrate is from the 4.7k Ohm 5W "cement" resistor.
See image 7 in the post https://pinside.com/pinball/forum/topic/thermal-regulation-ignorance-is-bliss-or-show-me-the-heat for the temperature of this sucker. 118.9C (Celsius) = 246F (Fahrenheit).
#8 1 year ago
Does that mean you elevate that single resistor a few millimeters above the board so that it's not touching the board?
My DMD was powering on when I first tried booting a few days ago as i could see it lit up with dots, but the machine itself wasn't booting. After a few on/off cycles, that's when fuse 601 blew and the DMD shut off. The machine not booting was due to the ribbon cables needing reseated so at least that part is taken care of.
It's gonna take me 20 minutes to solder a single one of these items let alone the entire kit. Marco's timeframe is for people who have been doing this for 30 years. My soldering skills aren't great, but I'm willing to try this to learn.
#9 1 year ago
Quoted from Flipper_McGavin:
A resistor that hot is going to dissipate heat in every direction. If the resistor is up against the board it will dissipate its heat directly into the board substrate. Eventually this will weaken the substrate. Worse still given that it is SO hot ... it will dissipate its heat to other nearby components as well.
Install (at the very least) that resistor elevated (raised) off the board. How much you elevate will dictate how much heat is dissipated into the surrounding air rather than the board or other components. Of course, you don't raise it "crazy high" off the board. There's no right or wrong with the amount. You want at least some amount for convective cooling into the surrounding air. Some of these axial form resistors have what could be considered standoffs to raise the body of the resistor off the board but there may still be a point of contact with the board. I install these resistors with no board contact at all. I want all the heat dissipated into the surrounding air as much as possible.
You can eliminate all this heat generation by using a low voltage display - either ColorDMD, PIN2DMD or an LED DMD display. If you opt to go down this route then you can simply remove the two fuses to disable the high voltage regulation and thereby remove all heat generation and dissipation. I am very slowly working through my machines to remove all the plasmas and replace with low voltage monochrome DMDs that I build myself.
#10 1 year ago
Yeah it's going to take way longer than 20 minutes. I've rebuilt probably 20 of those boards over the years and it takes me an hour to desolder, populate and then check continuity once I'm done.
Those kits are to rebuild the high voltage components that tend to get burned up. Not only should the cement resistors be raised up but also the diodes...especially the zener diode. Really the biggest problem is damage to the traces either from the heat or from removing components. Inevitably you're going to need some jumpers on the back side of the board to reconnect things back up.
The two large blue capacitors do not need changed out unless you're having a vertical scrolling display. I don't think I've ever had to change those on a WPC driver board yet.
#11 1 year ago
I raised mine about 1/2 inch. But again I insulted (spellcheck) then I insulated the leads with heat shrink.
#12 1 year ago
Quoted from DumbAss:
Sounds cool, how many 20 minutes' does it take to do that?
Could be a viable product, no?
#13 1 year ago
Quoted from schudel5:
Agree with this. I raise the 4742/4758/4759 zener diodes off the board. There is another 4742 in the 12V section that you don't necessarily need to raise off the board.
Don't forget the 47k Ohm 1/2W "bleed" resistors. Those can generate some heat well.
Agree with this too. These rarely fail. The other issue with this is that the specification is 150uF @ 160V axial but these are nearly impossible to find. A good substitute is 220uF @ 160V that Ed sells but unfortunately as most people know Ed's store is not open.
https://pinside.com/pinball/forum/topic/dumbass-test-and-reproduction-pcbs/page/12#post-6578684
It takes about 12x 20 minute sessions I would say. It's surface mount as well so it's not a lot of fun unless you like playing around with tiny components that you can easily flick off the table by accident.
$ 399.00
$ 27.95
$ 34.99
Rubber/Silicone
NO GOUGE PINBALL™
$ 1,059.00
$ 9.95
$ 189.00
Playfield - Plastics
Starcade Amusement
7,800
Castle Rock, CO
$ 84.99
FlyLand Designs
$ 9.95
Mitchell Lighting
$ 10.95
$ 69.50
Nezzy's Pinball Prints
$ 5.95
Mitchell Lighting
YouBentMyWookie
Jamestown, NC
17,250 (OBO)
$ 12.95
15,000
Ontario, CA
$ 329.99
$ 119.99
Cabinet - (Alt) Translites
FlyLand Designs
$ 60.00
$ 12.95
Pinball Pimp
Pinball Z
$ 225.00
FlyLand Designs
$ 225.00
Professor Pinball
$ 39.95
Hardware
RavSpec
This page was printed from https://pinside.com/pinball/forum/topic/white-water-fuse-601-blowing-for-dmd and we tried optimising it for printing. Some page elements may have been deliberately hidden.
