I am having an issue with the topper lights on my White Water not flashing and cycling as they should. I have checked all of the components on the chase board, except the capacitors, and everything SEEMS to be O.K. I do have a Rottendog Board installed and noticed at J1, pin 1 and 2 on the chase board that it was checking at 9 volts A.C., instead of 16 volts A.C., as specified in the manual. I am not sure if that would make a difference, but I was hoping someone could check what voltage they are getting on their machine.
Also, if you disconnect the connector at J1 on the chase board and replug it back in, the lights will change positions on the topper.
