My Bigfoot head doesn't turn. I've checked the motor with a 9 volt battery and it works, the red and white leads to the motor are intact and the bi-directional motor board is getting it's 12 volt and the LED is on. The C2 capacitor doesn't look like it leaked and I checked continuity on the traces that run under it. The only thing that seems a bit off is that diodes D1, D2, D3, D4, D7 and D8 test a bit strange in circuit. They all show the normal .6V tested in diode test on my multimeter in one direction but the other way they show 1.25V.
Could anyone confirm that that is normal or are they all suspect?
