I have just made a full teardown and rebuild of my White Water, but now I get an error that is a complete mystery to me, and I would really appreciate some help. I have tried to search the forum, but can not find anything like this, so here it goes.
When I turn on the machine I get the following error message:
And when I go into the Test menu it is correct that the 6th row is shorted as you can see below:
I have gone through the switches in that row, and found that the error is located at the Bigfoot Opto board:
The Bigfoot opto board had the following item number = 5768-13244-02
And looks like this:
Then I disconnect the Molex connector on the board the short error is no longer there:
The strange this is that if I connect the Opto board. I can run the Bigfoot test, and everything is working fine, even though the row is shorted as shown above. The head stops in the right places, and also when I turn on the pinball machine the self test that the Bigfoot head performs is done succesful. As seen on the following sequence of pictures, thet Bigfoot is working just fine in testmode:
And now to the mystery part, because the obvious assumption would be that the optos on the opto-board has gone bad, or there is some other component not working, but there are 5 components on the opto board, as you can see below:
And I have changed all of them, except from the resistors, but they measure out fine with my Fluke Multimeter. I have also resoldered all junction points, and measures all the connections on the opto board, and measured to find any shortages, but I can not find anything, but row 6 is still shorted when I plug it back in, and error is still there...Some times row 7 is also shorted, and that is the other opto. I have changed both optos with the exact same model and brand.
It is driving me crazy, and I do not know what to do...I am running out of ideas...
Any help would be appreciated...Thanks.
