(Topic ID: 204989)
White Water: backbox GI (help!)
By LawlorFanatic
2 years ago
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by cosmokramer
#1 2 years ago
I'm relatively new to Pinside, but I can't believe how much info is on here! I recently purchased a Williams White Water pinball. Cosmetically the game is beautiful, but a few of the GI headers were burnt after initial inspection, as well as some noticeable damage to the driver board. I decided to send the driver board off to be professionally repaired (CoinOPCauldron) and ordered replacement headers. After replacing the headers on board, the playfield GI (previously not working) came on. However, the back box GI remains dark. I pulled up the game manual, and J-121 appears to be a possible culprit. I've also read that blown fuses can prevent GI from functioning. After checking a few nearby fuses, and making sure the replacement header was properly set, the backbox GI remains dark- with the exception of two single lamps dimly lit when the game initially powers on. The game is playable, but looks funny without the backbox GI functioning. Any suggestions of where to start?
Thanks everyone for helping!
-Al
#2 2 years ago
There is a connector at J120 and J121. The one with the smaller wires goes to the backbox. The bigger wires goes to the playfield. Make sure it is plugged in tightly. Also make sure that the connector is not burnt, and if that is the case, the connector should be replaced. The fuses are 5 amp slo blo. Make sure they are correct and not blown
#3 2 years ago
You replaced both J120 and J121 connectors correct? Also J115 can also burn, this may cause some of the same issues you are describing as this connector brings in power to the board and then back out. Check that connector too.
You can swap the connectors for J120 and J121 around and see if the string of lights that don't work move. If you swap J120 and J121 and the backbox string is still out, the issue is in the connector wiring or lamps in the back box. If you swap J120 and J121 and now several strings on the playfield are out, then look for board issues (header pins, traces, broken plated through holes, blown fuses, etc.)
The manual towards the back shows what wire color goes to which pin on J120 and J121. Be careful when counting the pins because the pins on the board are numbered right to left.
#4 2 years ago
This may sound simple enough but did you check that the back box lamps are good, not burned out
I spent some time chasing my tail on a pin that the backbox lights wouldnt come on...turns out ALL the bulbs were burned out...
Trade
Machine - For Trade
Scranton, PA
Full Tilt Pinball LEDs
$ 349.95
Pin Stadium Pinball LEDs
$ 28.00
$ 159.99
