Finally splurged on a Whirlwind, the pin I remember most when I was playing at the bowling alley while my parents did league nights. It is otherwise in complete working order, except for the "adjust failure"/"factory setting" issue.
There is zero battery corrosion on this board. It is very clean and in excellent shape, so rule that out right away. The battery holder had been cut off long ago. I did remove the ram at U25 and installed a socket for a 6116 NVRam.
I have +5 at U25 pin 24, both sides of d1 and d3, and one side of d2. I did replace D2 and D3 just in case, but D2 shouldn't even be used anymore since there are no batteries anyway.
The NVRam is in working order as I swapped it over from my Big Guns temporarily, where it has been without issue for several years, until another one arrives for the Whirlwind.
The coin door closed memory protect switch is working correctly. With the coin door closed at power up I get "adjust failure", with the coin door open at power up I get "factory setting". When you power up with the coin door open and do the quick power on/off, it does go right into attract mode.
I have tried several times and it will never ever save any changed settings (to free play for example), and always comes back up with the same adjust failure/factory setting messages.
I did read some notes on NVRam and having to change jumper W5 to W6, but that is only with a dip switch settable NVRam, which this is not, so there should be no need to change that jumper at all.
You can power it up to the factory setting message, go through the menu to change the settings, cycle to the end of the adjustments menu and it comes up in free play mode and you can play the game. It will keep the high scores and settings until it is turned off. The game is 100% working otherwise, all lights, switches, coils, display, and plays great with zero issues.
I've played for several hours, and yet it never saves the changed settings or high scores after power off and I still have to rest it to free play for the next time I play.
I've never had this issue not go away after installing NVRam.
Any suggestions?
