After setting this aside for a few months I'm back at it. Still can't figure out why the upper right pop bumper will not fire. All coils have voltage. I replaced the suspect coil with no luck. I have looked through the manual trying to understand which connectors are involved and I think it's like this:
1. The red/white power wire that power sol#17, 19, 21, 22 (upper bumpers and ramp) is the J11 on the Aux Power Driver board to J5 on the Interconnect board to J11 on the same board to the pop bumpers. I have checked and reseated all the connections plus the fact that all those other sol work I ruled those connections out.
2. The switch wire (blue/brown) seems to go to J7 on the Aux Power Driver board. The other pop bumpers are also on that connector but I reseated all the wires to be sure.
3. In test mode you can push down the colored bumper wafer and it will register the switch # and make the bumper fire. When you push the one in question it tells you it's switch #49 but the bumper will not fire.
So if there is power to the coil and the switch is registering, what is it that tells the bumper to fire when the switch is triggered?
I'm hoping someone can look at this and see a gapping hole in my process and give some advice.
