Got a WW a couple weeks ago and it's been rock solid, no issues. I shopped it, added LEDs a few days ago, and played several games since with no issue. Tonight I swapped a speaker and did a few other benign mods and housecleaning: looking more closely at the boards, I made sure everything was seated tight (a few connectors did seem to push in a tad), and even replaced a couple missing mounting (grounding) screws.
Now when I turn on the machine, I am greeted with GI lighting only. No controlled lamps, no sounds, the alpha display (a blue rottendog LED) is dark, buttons do nothing.
MPU board diagnostic LEDs are all dark (the board is visibly pristine with NO alkaline damage). Pressing the CPU test switch does nothing.
I have checked, rechecked, and triple-checked all connections. I even removed the missing grounding/mounting screws I added.
It seems to me that the MPU board is not getting power, hence the lack of controlled lamps. But is a dark Alpha display and lack of sound related to that, or something else?
Trying to test the power supply... I am not sure I'm doing it right? Should be simple: on the 15pin connector use pin 1 for ground, then check the +5, +12, and -12 voltages on the other pins. Right?
But the readings I get make no sense at all! (what should be 5 reads as 0; +12 is 0 while -12 shoots into 90 at first... eventually they come into 12V, but I never get 5V. It makes me think my meter is suspect but when I check known good stable parts, the meter is fine).
...so I defer to the experts here. Help please and thank you!
