(Topic ID: 50669)
Whirlwind - Right ramp will not go up
By woofer768
10 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 10 years ago by xlnxminusx
#1 10 years ago
Hello,
Bought a Whirlwind in pieces. It had been stripped and cleaned and then the original owner died and I bought it.
This is the first table I have reassembled without taking it apart first. Everything is fine except the right ramp that goes up and down will not go up. If I start the game and pull it up, it knows when to go down but will not come up again. The mystery is that in coil test it works fine. Both up and down seem to have no problems.
Could anyone tell me where do I start this search. I have re-seated the j connectors in the backbox.
Thanks in advance, norman
#2 10 years ago
It gets more power in test, does it even try during the game ? If so maybe something is binding it.
#3 10 years ago
There is a switch that is depressed when one of the coil fires. This switch allows the machine to tell whether the ramp is up or down. The switch has an arm that can get loose and miss activitating the switch. This switch is often the cause of ramp up and down problems.
#4 10 years ago
Just got back to pinball. LTG, During the game, the other coil that lets the ramp down "Clicks" 3 times. But it is not the one that pushes the ramp up.
Thanks Boo, I will look for that switch. I am guessing it will be near the coils that fire the ramp. Do you know what switch it is or where it is located? I'll let you know if I find it.
Thanks all,
norman
#5 10 years ago
Hello,
Just saw the switch under the ramp. Thanks Boo. It is loose as a goose. I am sure this is the issue. I'll let you know when it is fixed!
norman
#6 10 years ago
That worked great! Ramp is good. I have another Whirlwind issue. I will just keep going .
The light on the right cellar door is on all the time when you start a game. The right inlane is supposed to turn it on for a moment and it should go off. The right cellar door is also not scoring. It does make the correct sound effect (so far as I can tell) and the ball ejects correctly from the left cellar door. Interestingly, the bottom upper Jet is also on all the time when you start a game.
Both the Right Cellar Door and the bottom jet light up and work correctly at table start and test mode. But when you start an actual game the light is on.
I have seen no problems with any switches down there and I see no issues with 1J7 or 1J6.
Hope someone can help me. Thanks in advance,
norman
#7 10 years ago
There should be two switches in the cellar tunnel. One to tell when a ball is at the plunger to be kicked out, and one when it rolls from the right hole over to the plunger. Check the switch for when the ball rolls from the right hole over to the plunger.
The cellar starts off lit on each ball (unless you changed the settings), and is unlit after you collect the award. It can be turned back on by the right inlane, or hitting the left ramp.
$ 18.95
$ 399.95
Pin Stadium Pinball Mods
Led
This page was printed from https://pinside.com/pinball/forum/topic/whirlwind-right-ramp-will-not-go-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
