Quoted from gypsycat:checked voltage IJ17 getting 4.39 volts on those 3 pins also my rollergames is getting around the same voltage and no issues with that game as i'm a novice my mate told me not me not to mess around with the roms voltage as it can blow things up if not done right
That's too low. Usual suspects are failing capacitors (dried out electrolytic filter capacitors) or connector problems. Check at the power supply, if it is significantly higher, you likely have a wiring/connector problem. If it is close to the same voltage, your power supply needs attention.
TTL gates operate on a nominal power supply voltage of 5 volts, +/- 0.25 volts. Your lucky that Rollergames hasn't had a problem, but it could glitch on you at any time.
