(Topic ID: 221826)
Whirlwind pf restore and clearcoat started today
By joey__p__1966
9 months ago
  • 32 posts
  • 11 Pinsiders participating
  • Latest reply 25 days ago by joey__p__1966
  • Topic is favorited by 12 Pinsiders
There have been 36 images uploaded to this topic. (View topic image gallery).
#1 9 months ago
Here I go again on a pf restore. Not as bad as my Taxi, but will keep me busy for a while .
Took it on a barter for clearcoat services for a friend. Just getting the Mylar glue off is half the battle . I use 90% alcohol and a plastic razor blade , then roll my fingers across the dried alcohol until it balls up . Flour wasn't needed on this one, but helps if it isn't coming up easy.
Looks like I will need to do quite a bit of painting , so after cleaning up all of the ball marks with magic eraser , cleaning up the raw wood areas , and sanding the ball shooter lane it's about ready for the first cleat coat application. I'll put down 2 coats to isolate the old paint and begin my art reconstruction . One nice thing is inserts are level, so not going to have to build up with extra clear on this one.
Question for the group: what to do with the raw wood around the spinning disc ? It's to dirty to sand without sanding off too much wood, and it's kind of nasty looking. Leave it , or take the black all the way into the cutout ? Paint it light tan? What do you think here?
Joey
IMG_0204 (resized).JPGIMG_0216 (resized).JPGIMG_0230 (resized).JPGIMG_0234 (resized).JPG
#2 9 months ago
Looking forward to watching your progress!
#3 9 months ago
Hey I recently bought a Whirlwind play field myself, its condition is much the same as yours.
I will be watching your progress very closely to see how you go.
I will put some pics of mine up on the weekend if you are interested.
Thanks.
#4 9 months ago
Quoted from griffo84:
Thanks.
Yea, shoot up a pic ! Hope to get some time this weekend to clear mine. I am sure there is a decal set available , any better than another? Gotta couple inserts that I'll either touch up or sticker, or water slide decal .
Joey
#5 9 months ago
Ready for clear . Three inserts will need to be repaired , so I scraped off the partial text , and sanded with 1000 grit to smooth out the insert. I Grey scotch brite the whole pf for adhesion , cleaned the crap out of it with alcohol and glass cleaner. Decided to spray a light brown where the wood is so ugly around the spinning disc, to simulate the wood color. It’s only a small sliver of color that will show , and will look better than discolored wood .
Should get to clearing it Saturday , then start with the color matching .
Really not much insert lift , so got lucky with this one.
Joey
4AB479FD-CB58-4630-A255-4727083C2CB6 (resized).jpeg4E72C70E-B2B5-4BEC-9BAB-D0DB5DC91A9B (resized).jpeg7B68FB4C-54C9-493C-93A2-6967B85CAF54 (resized).jpegBACF2D3D-38F6-4477-A88A-023FF51391D2 (resized).jpegC9572818-FEFE-45D9-8360-59D011633021 (resized).jpeg
#6 9 months ago
Excellent! So many Whirlwind restores in the ATL over the last year. Great to see another one!
#7 9 months ago
Tuned in. Looking good.
#8 9 months ago
Quoted from damadczar:
I just have the pf though , I have a ww and a Pinot to restore . Not sure what I'll do with them once done, might sell or trade for something , who knows . I just enjoy the challenge of the restore .
#9 9 months ago
Quoted from chad:
Thanks !
#10 9 months ago
First clearcoat down , 3 coats . Use Akzo Nobel products , have my pick but choose Utech 4.0 clear, as it does well in a no booth situation with minimal air flow. Low Voc , super high solids clears like lots of air movement , and a medium solids clear does better in garage shop conditions.
Next I’ll sand it with 800 grit on a DA sander using a interface pad to level it a bit without breaking through at the inserts . Grey scotch the areas I can get into and begin the colors .
I got lucky, last night I went through the paint I used on my Earthshaker and found maybe 5 colors I needed for this. So that helps save time for sure.
Off to the lake , for a FFO( fun family outing)
Joey
9F1663AF-6A51-42F5-BBC2-F152326B82A8 (resized).jpegDF192980-687F-4987-BDB7-14955C583FA7 (resized).jpeg
3 months later
#11 6 months ago
Spent some time on it now that softball season is over. The frisket did fine , even though it said no solvent paints, however I kept the coats light , as I could see where a semi wet coat would have lifted it right up. Blue upper area done, but had clear lift on an insert where I had masking tape , so gotta fix that now , damn system 11 games
I use automotive basecoat , thousands of color choices , and it’s my profession .
Back on track, more progress to come .
2A872B94-E18D-459A-B071-5D0296231F5A (resized).jpeg53797F92-5EFB-4080-AF92-DE09FC35E8E6 (resized).jpeg78958C5D-2362-4C89-9A5A-BA45C31B5FDB (resized).jpegFCEEC16E-FB68-4395-8118-0910A2186B8E (resized).jpegimage (resized).jpg
#12 5 months ago
More progress today , sprayed red. Still have some brush touch up to do, intricate masking left some areas to finish by fine brush.
As of now , white, light blue, green, and red are done.
Next up will probably be dark blue and another couple coats of clear.
1BDC7EF6-F052-400C-BC77-3B5B9928A5F9 (resized).jpegF5164493-02CB-4FCC-A640-02110C3C2DCF (resized).jpeg2AE7D3DB-260F-493B-9DD1-1714BA1F1638 (resized).jpegA08A17C2-AACE-4593-AA69-9EE632D165B7 (resized).jpeg
1 month later
#13 4 months ago
Spending New Year’s Eve watching football and cutting out the yellow .
Gonna have yellow sprayed by end of day tomorrow , I hope.
X-acto blade and crown royal might not mix
#14 4 months ago
#15 4 months ago
Happy new year! As planned the yellow is getting done today.
Prolly clear it again.
#16 4 months ago
Looking great, popping already
3 weeks later
#17 3 months ago
Finished the orange , did a little dark blue also. The white and Black tornado is gonna be next , along with the kickback lane, and flipper wear spot. That should about finish the colors, then gotta outline everything in black with a fine paint pen or fine line pinstripe tape.
This one will probably have taken 9 months when done, but it’ll be super nice for an original.
18473396-044D-4A52-91CD-F26872EF239D (resized).jpeg1EADB68F-9FAB-466D-8171-C6CE4683C235 (resized).jpeg383D9889-674E-4D74-98EA-DD67CEA38E2A (resized).jpeg551E072A-A27C-4B31-A1CD-B908BECC13D0 (resized).jpeg48BD2E4F-65DB-41F5-ADAD-7AAF8F54DF90 (resized).jpeg50563718-C4CE-4F20-8EC2-C4A8B193814C (resized).jpeg8283DA81-974D-4724-ADF0-C576793F2036 (resized).jpeg
#18 3 months ago
Nice job!
#19 3 months ago
Thanks Man, appreciate the complement.
1 month later
#20 77 days ago
More progress this weekend, all that is left is the left tornado and a few inserts .
It’s been 8 months in the making , think I’m about 3 hours shy of having this one done .
Here is where I’m at. Check out the pics and video .
Joey
0C58C799-6E40-47DE-8E02-557C1599D69B (resized).jpeg1625B8D1-5E3C-4428-900A-CDBC5BA19B55 (resized).jpeg72E1F81E-80B7-4675-AF19-8D661EC3B5C4 (resized).jpeg
#21 77 days ago
Wow. Looks great. I have a Whirlwind that could use this treatment. Nice work
#22 77 days ago
Quoted from WyseGuy:
Thanks, it’s the part I love most about the hobby .
This one was the worst I’ve ever started out with , I have a Pinbot waiting to do next , it’s pretty bad also. I don’t even have a WW anymore , just doing this because it’s fun to see what I can do with them , and bring an old pf back like new .
Joey
#23 64 days ago
Just out of curiosity, did you seal the back side of the PF as well?
#24 55 days ago
I just finely sanded the backside and left original. Mainly to remove any coil dust .
Only working on topside .
JP
#25 55 days ago
Looking good
3 weeks later
#26 29 days ago
So I finally took on the hardest part of the touch up, the tornado on the left side. Came out better than expected, so now I want to do the right side, just to get it nice and bright like its supposed to be . Al that’s left is one insert , that right tornado, and a final clear coat once the pollen gets out of here.
199756C3-F30D-4DE6-9B95-3FE0DDD191CE (resized).jpeg3B93CDBF-1901-4977-9093-534CDDE14D9F (resized).jpeg8C031231-B3BE-4155-93B1-5DABB91B6A6F (resized).jpegCF0643DB-4E21-4DF3-9EBF-82413EC602D0 (resized).jpeg
#27 29 days ago
It’s been one year to the week that i got this old pf from a buddy , looked so bad when I started that I wasn’t sure if it would be worth the time. I wonder how many hours I have into? Just doing it for the fun of it, as I don’t even have a WW any longer , but feel i saved it from the dumpster .
#28 29 days ago
Nice job! Need to pay you a visit sometime with damadczar
#29 29 days ago
Quoted from kermit24:
I’d enjoy that, most evenings and every other weekend if free.
#30 28 days ago
Quoted from joey__p__1966:
Heck yeah man. I know last time I was over it was just for the Defender paint, but should come over for pins.
And you are welcome to my house anytime Joey.
#31 28 days ago
I wish I had the time and skill to do this stuff like you and mitch. I'd buy cheap playfields and fix them up to hang on the wall.
#32 25 days ago
I wish I had the electronics background , i struggle with that , that’s why we complement each other making the hobby a friendship.
I do get attached to the ones i restore , it’s like a painting i just spent a year on and it’s hard to let it go.
Mitch makes the tough stuff easier with the masks that’s for sure .
