No feature lamps in game or test mode. Here's what I know:
-the 8a fuse next to the big capacitor checks out fine
-the bridge rectifier seems to check out fine (.6 when measuring + to AC leads; same for - to AC leads; perfect continuity between + and - (is this right? I think it is, but just checking))
-no burned connectors
-when removing 1J6 and 1J7, I checked with a 555 lamp socket and 1n4007 diode and got nothing for any of the columns or rows
-when grounding Q80 through Q87, no lamps light
What's my next move? Do I replace the PIA at u52, the 7408 at u52 and u53, and/or the 7406 at u55 and u56? Is there a place I can measure if I'm actually getting proper voltage to the MPU board for the feature lamps? Many thanks
