(Topic ID: 207384)
Whirlwind - My first resto
By orangegsx
6 years ago
  • 77 posts
  • 12 Pinsiders participating
  • Latest reply 5 years ago by orangegsx
  • Topic is favorited by 18 Pinsiders
There are 77 posts in this topic. You are on page 1 of 2.
#1 6 years ago
I know there is a ton of whirlwinds on here, Just wanted to add mine and see if anyone had some tips for me along the way, I've already started but anyways, here it is.
I played whirlwind as a kid at the local pizza joint, never thought I would end up with one (or afford one) but got lucky and found one in town and did some trading. This is my holy grail pin for sure. The game was not operational when I got it. Replaced the resistors for the displays and that let me figure out what was going on and played a few games on it. I wanted to clean it up good before I did any more damage to it, it was very grimey. I plan on getting it cleaned up as good as I can and getting it playing good. I don't mind the patina on the cabinet (for now at least).
38979849214_79f4461d81_k (resized).jpg38979849214_79f4461d81_k (resized).jpg
38791081715_179778c1e0_k (resized).jpg38791081715_179778c1e0_k (resized).jpg
25816585068_7e97f5bcc5_k (resized).jpg25816585068_7e97f5bcc5_k (resized).jpg
25816631628_e1426a1b4b_k (resized).jpg25816631628_e1426a1b4b_k (resized).jpg
39657811712_0aee0940d6_k (resized).jpg39657811712_0aee0940d6_k (resized).jpg
25816633658_68cfa3e6c1_k (resized).jpg25816633658_68cfa3e6c1_k (resized).jpg
38979889554_14993d6bfb_k (resized).jpg38979889554_14993d6bfb_k (resized).jpg
38979838884_548094f019_k (resized).jpg38979838884_548094f019_k (resized).jpg
24820005617_777783597c_k (resized).jpg24820005617_777783597c_k (resized).jpg
24820011337_0ad193a525_k (resized).jpg24820011337_0ad193a525_k (resized).jpg
39657741672_60bdf82640_k (resized).jpg39657741672_60bdf82640_k (resized).jpg
having an ultrasonic to use is awesome, also don't know how I lived without a tumbler before!
39657751382_faf4ef6a9d_k (resized).jpg39657751382_faf4ef6a9d_k (resized).jpg
25816589608_8753cdca19_k (resized).jpg25816589608_8753cdca19_k (resized).jpg
39688757461_8c1d4900fc_k (resized).jpg39688757461_8c1d4900fc_k (resized).jpg
24820010257_a8d9afb35b_k (resized).jpg24820010257_a8d9afb35b_k (resized).jpg
38791082165_fcfff8c738_k (resized).jpg38791082165_fcfff8c738_k (resized).jpg
I've done some touch ups and a few insert decals, I have a play field protector to put on over it all, Just waiting on my cliffy's to show up before I do that. Had to order a couple other bits too so I'm sort of on hold right now.
#2 6 years ago
Quoted from orangegsx:
I played whirlwind as a kid at the local pizza joint, never thought I would end up with one (or afford one) but got lucky and found one in town and did some trading. The game was not operational when I got it. Replaced the resistors for the displays and that let me figure out what was going on and played a few games on it. I wanted to clean it up good before I did any more damage to it, it was very grimey. I plan on getting it cleaned up as good as I can and getting it playing good. I don't mind the patina on the cabinet (for now at least)
That's cleaning up nicely. Keep us posted.
#3 6 years ago
Excellent work. Will be following for when I start mine.
#4 6 years ago
Looking good. I just recently stared mine, and replaced a bunch of the stock stuff. Let me know if there is anything you need.
#5 6 years ago
Thanks all. I'll let you know if I need anything nerdy, I actually followed you on instagram to follow your swap.
Sanding on some ball guides tonight, they are all pretty nasty and I'm running out of sandpaper. My cpr plastics should be here tomorrow and hopefully my cliffys!
Had a friend tig up the cellar too, should hold now.
#6 6 years ago
One question I did have. Is there anyway to stop the upper flipper from hitting the ball guide? Or do I just have to keep extra rubbers around?
#7 6 years ago
Go get yourself. Flapping wheel to help with regraining the ball guides, it goes quick
#8 6 years ago
Quoted from dsuperbee:
What grit? I think I have some at work. I've been starting at 600 and ending with 1000 by hand.
#9 6 years ago
I have one, can't remember the grit, but probably 600.
#10 6 years ago
Wowzer, that appears to be an adjustment issue, either with the way the flipper was set or where the ball guide is sitting. It's something to be aware of when reinstalling, check your spacing and adjust flipper accordingly.
Also kudos for taking the time to regrain. I've been on the fence about it, but it may be a nice break from the PF stuff. The flaps are awesome. I've heard these work great too, but only go up to 400g: https://www.harborfreight.com/4-in-400-grit-abrasive-ball-61183.html
#11 6 years ago
Quoted from nerdygrrl:
Hmm. Well I think I'll order some flipper stops just to make sure.. it beat up the ball guide pretty good
#12 6 years ago
Plastics showed up. Impressive quality. Quite the upgrade
#13 6 years ago
Still waiting on parts, have a few other projects to finish up before I continue too. I did get a new light cover for my box at work though
#14 6 years ago
Well I think I figured out my display issue. Missing chip at u19, easy and cheap enough. Also found a bad relay underneath the playfield for the upper GI, having some trouble finding one though.
Still waiting on bumper bodies then I can carry on. Got the playfied protector on, looks great
Threw in a clear hole protector too, with a blue LED below it.
#15 6 years ago
You got any 455s in that led assortment for the backbox?
#16 6 years ago
Quoted from TheLaw:
I was trying to figure out why I was six bulbs short up there. Now I get it. Forgot to order those. Thanks!
#17 6 years ago
replaced fuse and reflowed relay board.. woohoo!
#18 6 years ago
Well last night after getting the GI working I went after the spinning discs problem. Assumed it was the resistor on the motor board so I resoldered it, then resoldered the sound overlay board... then I found the single butt connector unplugged that goes to the motor . So my only issue left is the missing chip for the display. (Hopefully)
Heres a shot of the lit up eject hole. This will be the only colored LED out of an insert.
#19 6 years ago
Looking great!
Were you able to find U19 UDN7180? Don't buy these from China, they are most certainly fakes.
#20 6 years ago
Great progress, everything is looking awesome so far!
#21 6 years ago
Quoted from Schwaggs:
Looking great!
Were you able to find U19 UDN7180? Don't buy these from China, that are most certainly fakes.
Thank you!
I was going to order one from action pinball today. I'm assuming they are fake though? For 8$
#22 6 years ago
Thank you!
Maybe someone found a bunch of tubes of them in their backstock. BUT, $8 is a steal, even when (if) you can find them in stock somewhere trustworthy they can be $15-20 each so be cautious. Hopefully they didn't source them from China. If you do buy spares, test all of them in your board to make sure they work before storing them. Maybe perform the diode test as described on PinWiki before installing them. http://pinwiki.com/wiki/index.php?title=Williams_System_9_-_11#Display_Fuse_F1_Blows
#23 6 years ago
So far the bumpers are the first thing that I am not fully enjoying working on. Only five more to go though!
#24 6 years ago
Had to give up on the bumpers for the night and move on, half done.
Slapped some decals on the drops
5C7C374B-6336-4F60-8283-66BBEFDB9F4C (resized).jpg5C7C374B-6336-4F60-8283-66BBEFDB9F4C (resized).jpg
#25 6 years ago
Bumpers are pretty much the worst of it. There is nothing more miserable. You're doing great and they look sick!
#26 6 years ago
Getting there. Ramp day today!
#27 6 years ago
Looking great!
Did you do any touch-ups to the PF before installing that makrolon protector?
#28 6 years ago
Quoted from mgpasman:
Looking great!
Thanks! I did a bit around the bumpers, nothing major though. I did it with acrylic and did not clear it. There is a few pics of what I did on the first post.
#29 6 years ago
Ah, now I see it. Great result though!
#30 6 years ago
Added a small hunk of metal to help stop the ramp from cracking.
#31 6 years ago
I ordered bayonet bulbs for the top lighting piece instead of wedge. Oh well incandecants will work for now. I have some adjusting to do for sure. kind of wish the tolerance on the playfield protector was a little bit tighter around the spinning discs
#32 6 years ago
Ugh... replaced the chip... the lower half now works but its still jumbled
#33 6 years ago
Check your ribbon cables, reseat and check continuity. 99.9% likely it's a cable issue.
#34 6 years ago
Hmm.. I flipped both ends 180* you would think the problem would change but it didn't at all
#35 6 years ago
Well looks like a pin was folded under on that socket while it was replaced or something.. crap
#36 6 years ago
Looks damn close at that legs on the chip and make sure they're all firmly seated. Those little bastards are sneaky
EDIT: Ha posted as you were. As long as the leg is still attached it's fine. Just bend it back CAREFULLY.
#37 6 years ago
Well, that looks to be pin 9 which is ground. No telling what would happen with that left floating. Great eye to catch that missing pin.
#38 6 years ago
Well I removed the chip socket and resoldered it. Reflowed most everything else again to make sure.. making some progress here but now the top characters are stuck on.. doesnt change when flipping the cable
#39 6 years ago
Do you have another display or ribbon cable on hand so you can rule the display or cables out?
#40 6 years ago
No unfortunately. I'll check the cable for continuity tonight.
Here is the display test. Im not sure on what exact segments they are I'll have to look them up. But the tops are stuck on and some of the bottom is missing.
#41 6 years ago
The cable has continuity through all terminals. Looking at the schematic now I guess I'll check and reflow everything upstream tonight
#42 6 years ago
Hmmm
#43 6 years ago
Toasty
#44 6 years ago
#45 6 years ago
I'm guessing a component on the mpu is toast, one of the src's... I've gotta take a break from this before I ruin something I can't afford to replace right now. Reflowed a bunch of stuff on the cpu and nothing has changed. I'll do some more research and come back to it I guess
#46 6 years ago
Wow, that looks like my old HS CPU. It should be easy enough to test the continuity of those traces to make sure they are all in tact.
I've got a great board repair guy out here. He's setup with all of the Williams test rigs. If you want his name I would be happy to pass it along.
#47 6 years ago
You have a couple problems in those pictures, lets start with the top segments of display 2 locked on.
Now that you have replaced the missing 7180, lets step slightly back. Use a logic probe to test the inputs and outputs of the input buffers for those segments. Looks like a, b and f segments which come through U9 and U10. These should be pulsing and NOT stuck high or low. If they are stuck hi or lo on the input, you have a ribbon cable or CPU board issue. If the input is pulsing but the output is not, you have a bad buffer chip.
Similar test for the display 2 segments that never turn on c and e. Those input buffers are on U11 and U12
For the dead digit and the always on digit in display 1 and 2, we know the strobe signals are making it through the input gates since digit 5 has a problem on display 1 and digit 4 has a problem on display 2 (if the signal was not making it through, both displays would have a problem on the same digit). The problem is probably in the 6118 at U13 and U17. Are either of these socketed?
#48 6 years ago
Send board out for looking over. Coin op cauldron.
You've spent a lot of time on this thing. Get the board bulletproofed. Also, change out those weird batteries.
#49 6 years ago
Ive been meaning to get a logic probe for work, I'll get one and dig into this. As far as the dead digit it was going through the test where is goes through all the digits one by one.. there is no problems with the top display. Thanks for the help. I will go through it when I get a logic probe
#50 6 years ago
Cool, then there is only a potential problem with U17. Is that by chance socketed? If so, check out the solder job on that socket and if another 6118 is socketed, it would be a simple test to swap them and see if the problem follows the chip.
$ 18.95
$ 27.00
Metal-Mods
Precision Pinball prod.
$ 399.00
8,500 (OBO)
Bakersfield, CA
$ 16.50
$ 54.99
$ 90.00
$ 45.95
Middletown, OH
$ 899.00
This page was printed from https://pinside.com/pinball/forum/topic/whirlwind-my-first-resto/page/1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
