Hi
Anyone deck out there backbox in "WHIRLWIND" in LED's at all? If so, do you mind sharing what color scheme you used or showing it at all? Thanks in advance!
Dan
Hi
Dan
I used a mix frosted white warm single SMDs, warm white 2 smds (that I frosted by hand with sandpaper), and one or two ultra bright warm whites. The ultra brights went in areas where the art is meant to look closer (enhances the depth of the image). I also used 1 or 2 red frosted bulbs on the van (careful not to colorized the flesh tones) and one frosted blue on the far right caravan.
Art at comet piball helped me select the various brightness of white bulbs.
Looks great with no hot spots
Quoted from tdiddy:All cool whites
Ditto. After a TON of experimentation, this was what I thought looked best.
Quoted from TomGWI:I used cool white frosted and then blue frosted for the Whirlwind lettering.
This is me also, add a slow fade color changer behind the van's weather thingie on top.
Quoted from TunaSled:This is me also, add a slow fade color changer behind the van's weather thingie on top.
That's a great idea. I will try it out.
This page was printed from https://pinside.com/pinball/forum/topic/whirlwind-led-backbox-set-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
