I had to remove the diverter to replace my ramp which broke. Now, the diverter is not functioning correctly.
When I light the lock, the coil fires and the diverter moves so that the ball goes to the lock.
The problem is that after the ball is locked, the diverter does not return to the position to return the ball to the left flipper when the lock is not lit. Should the coil fire again to return the diverter or should tension of spring on the diverter arm return it to the ball return position when the coil does not fire? If so, maybe I have installed the arm incorrectly.
I think the diverter should always be in the position to return the ball to the left flipper unless the locks lit.
Any photos of the underside of the diverter assembly would be a big help.
