(Topic ID: 286361)
Whirlwind complete restoration
By cconway84
  • 45 posts
  • 12 Pinsiders participating
  • Latest reply 2 years ago by cconway84
  • Topic is favorited by 11 Pinsiders
#1 3 years ago
I picked up a Whirlwind and a Met pro from the PAPA / replay foundation asset sale. I’ve always enjoyed Whirlwind more than any other pre DMD titles. When I bought it I planned to enjoy it as a players game that needed minimal work. However one thing led to another and here I am.
I used hooks in the ceiling and chained up the playfield while the game was elevated on a harbor freight lift. After chaining it up I simply dropped the lift lowering the cabinet out from under the playfield. Worked well as a method to remove the pf with one person.
29E5C01E-D163-4B50-B103-7A412F2FBFF1 (resized).jpeg29E5C01E-D163-4B50-B103-7A412F2FBFF1 (resized).jpeg7DF7F482-B332-44C3-AF9B-C95CA4EE9F73 (resized).jpeg7DF7F482-B332-44C3-AF9B-C95CA4EE9F73 (resized).jpegAC5E4303-DC2B-4809-8A44-9E26028CE348 (resized).jpegAC5E4303-DC2B-4809-8A44-9E26028CE348 (resized).jpeg7D6733B9-8E61-42DB-9924-52B4112662B3 (resized).jpeg7D6733B9-8E61-42DB-9924-52B4112662B3 (resized).jpeg0D649743-B14B-4AB9-BAB8-E66DCFE2F28C (resized).jpeg0D649743-B14B-4AB9-BAB8-E66DCFE2F28C (resized).jpegA294C12C-AE03-4571-BD6F-15F72421CB95 (resized).jpegA294C12C-AE03-4571-BD6F-15F72421CB95 (resized).jpegAE279F86-2097-47F4-9FEB-93ECE6934FF7 (resized).jpegAE279F86-2097-47F4-9FEB-93ECE6934FF7 (resized).jpegF03CDE35-FA8F-44E4-B53B-4620C759A307 (resized).jpegF03CDE35-FA8F-44E4-B53B-4620C759A307 (resized).jpeg22300238-DFE5-4D29-B385-4495273137F3 (resized).jpeg22300238-DFE5-4D29-B385-4495273137F3 (resized).jpeg
#2 3 years ago
This was my first project using a rotisserie and it is so much easier. I built it with the plans on pinside out of parts from Home Depot. Probably have about $180 in it including some tools used to make it.
EE58161E-32DD-4BB6-AB44-B70E387660F1 (resized).jpegEE58161E-32DD-4BB6-AB44-B70E387660F1 (resized).jpeg
#3 3 years ago
Tumbling metal parts is one of the easiest ways to clean up a game.
A484CE0F-5D87-4CA3-AF41-F42CF8C3FC97 (resized).jpegA484CE0F-5D87-4CA3-AF41-F42CF8C3FC97 (resized).jpeg
#4 3 years ago
Every machine I bring home gets a new heavy duty wall plug. Cheap insurance to replace old frayed parts.
001B7836-1B14-4403-8C67-D718B6960250 (resized).jpeg001B7836-1B14-4403-8C67-D718B6960250 (resized).jpegBD8CB3B1-D033-422F-856E-8B249F2FD1CE (resized).jpegBD8CB3B1-D033-422F-856E-8B249F2FD1CE (resized).jpeg
#5 3 years ago
I used HEP’s idea to cut off all solenoids from the wiring harness. I placed new molex quick detach plugs 2-3 inches in on harness to make the swap easier to work on. Will also make future work on mechanisms easier as they can be pulled from the game quickly to work on them at the bench.
New springs, coil sleeves, coil wrappers, etc. all metal parts cleaned with simple green, tumbled. Everything rebuilt to look new again.
Once the mechanisms were off the last things to go were the three wiring harnesses.
75CF1F96-E289-4C67-8D74-396FACA54507 (resized).jpeg75CF1F96-E289-4C67-8D74-396FACA54507 (resized).jpeg460D36F5-5C84-4FCA-89E8-AF75407930A2 (resized).jpeg460D36F5-5C84-4FCA-89E8-AF75407930A2 (resized).jpegEDC8EBAA-2BD1-44ED-9901-757C8F8B741B (resized).jpegEDC8EBAA-2BD1-44ED-9901-757C8F8B741B (resized).jpeg8102D9E0-24A9-4931-9C45-0E41955FBA8E (resized).jpeg8102D9E0-24A9-4931-9C45-0E41955FBA8E (resized).jpeg1D367560-E512-4D4D-8001-5DB93EE0D1BC (resized).jpeg1D367560-E512-4D4D-8001-5DB93EE0D1BC (resized).jpeg343CEC04-9CA4-40EE-BF7C-80455C62CF73 (resized).jpeg343CEC04-9CA4-40EE-BF7C-80455C62CF73 (resized).jpeg
#6 3 years ago
Great start. Following!
#7 3 years ago
Harnesses washed in the dishwasher (except enclosed micro switches). Metal parts all go into the tumbler.
Any time I tumble a number of small parts I always take a picture of them before tumbling. Then when they come out I can compare to the picture to make sure I got them all back out. Helps avoid being a post short during reassembly with no idea where it could be.
14C0C7BB-861E-4E14-874B-73962D059983 (resized).jpeg14C0C7BB-861E-4E14-874B-73962D059983 (resized).jpeg53D426F6-4583-49F9-B23D-33E5447088A0 (resized).jpeg53D426F6-4583-49F9-B23D-33E5447088A0 (resized).jpeg
#8 3 years ago
All ball guides are regrained with a 80 then 120 grit flap wheel using a drill. Before and after in each photo.
6819CE00-0E21-426C-B76B-B665B194D5A8 (resized).jpeg6819CE00-0E21-426C-B76B-B665B194D5A8 (resized).jpegCC491398-3542-433E-ACCC-8612A5AF6ED2 (resized).jpegCC491398-3542-433E-ACCC-8612A5AF6ED2 (resized).jpeg
#9 3 years ago
Quoted from cconway84:
[quoted image][quoted image]
I have never had the guts to wash the wire harness in the dishwasher. I know people do it. What can go in and what can't? Do you just air dry for some period of time?
It always seemed like more risk than reward as no one see the wires anyway and what if I short something.
#10 3 years ago
Quoted from killerrobots:
I put mine in a normal cycle, and when it's done (including some drying), I hang up the harness on a hook for a day. if there is a sensitive part I'm worried about corroding, I put a small zip lock around the part with a rubber band. An example might be a connector I'm concerned about exposure to water, etc. That being said, I've put them in without that an never had a corrosion problem.
#11 3 years ago
Quoted from jsa:
Thanks for that. Maybe next time.
#12 3 years ago
About to start striping my Whirlwind for restoration. Keen to see how yours goes.
#13 3 years ago
I’ve done my whitewater and whirlwind harnesses in the dishwasher so far. Normal cycle with a washer soap pod. Make sure no stray wires are hanging down through the rack as it will get caught by the spinning rinse attachment. All connectors, light sockets, open switches, etc can get wet. After it is done the harness is hot and flexible. I set it on cardboard then hang it to dry later for 24hrs or more. If vid recommends it that is good enough for me.
Biggest risk is just handling the harness can break old solder connections. I have 3-4 breaks at gi light sockets that will need soldered up again.
Isn’t needed but so nice to have a fresh clean game. I’m going for that nib look.
#14 3 years ago
Old and new playfields side by side. Any opinion on value of old pf? Some planking, wear above spinners, some raised inserts. Will probably part with it after my swap is finished.
2D4EE34D-98D9-4879-8E32-BDACF8D96CD0 (resized).jpeg2D4EE34D-98D9-4879-8E32-BDACF8D96CD0 (resized).jpeg43B2F65F-589B-463F-B8F4-B2582040BDD9 (resized).jpeg43B2F65F-589B-463F-B8F4-B2582040BDD9 (resized).jpegA938617B-DF55-4AE1-9270-9577FB40C5A1 (resized).jpegA938617B-DF55-4AE1-9270-9577FB40C5A1 (resized).jpegD8698C67-9D73-4A6D-8B59-3133642ECFA3 (resized).jpegD8698C67-9D73-4A6D-8B59-3133642ECFA3 (resized).jpegEC38231F-ED96-4178-B8FC-7345AF097204 (resized).jpegEC38231F-ED96-4178-B8FC-7345AF097204 (resized).jpeg
#15 3 years ago
I would give you something for your old one. I like restoring them and have a Whirlwind I might do one day.
#16 3 years ago
New playfield t nutted and drilled. I used contact paper on the old playfield as a template for the drill holes. Sticky enough to stay but easily removable. I punched holes with an awl in drill holes and used sharpie to draw where the inserts were. Then I transferred over the contact paper to the new playfield, lining up the inserts and holes. Then drilled new holes using the contact paper as my guide.
17BD9275-536D-48EF-9373-5E232947549E (resized).jpeg17BD9275-536D-48EF-9373-5E232947549E (resized).jpeg
#17 3 years ago
#18 3 years ago
I wanted new playfield rails to replace my beat up cheap vinyl wrapped ones. Reese rails isn’t currently taking orders so I got some new ones courtesy of my father in law. 1/2” oak ripped down to 1 1/8” height and cut to length. Ebony stain. Clamped into position and screw holes drilled from below using playfield holes to line it up.
Old vinyl wrapped rail and new oak rail in comparison photo.
10656B82-E29E-44DB-8D83-7DB49EA8915E (resized).jpeg10656B82-E29E-44DB-8D83-7DB49EA8915E (resized).jpeg5515E6D1-10DF-4534-AF51-29C63B3E51D5 (resized).jpeg5515E6D1-10DF-4534-AF51-29C63B3E51D5 (resized).jpeg9CFC7B3A-E0F6-4A72-B061-C75CC06AAA6B (resized).jpeg9CFC7B3A-E0F6-4A72-B061-C75CC06AAA6B (resized).jpegC8C5C5E9-5D49-4933-9CED-55CFA76F5CD4 (resized).jpegC8C5C5E9-5D49-4933-9CED-55CFA76F5CD4 (resized).jpeg33892795-5C63-4119-91C4-D56336AB4E42 (resized).jpeg33892795-5C63-4119-91C4-D56336AB4E42 (resized).jpeg2DE54C41-E280-4860-B15B-24247FF3F0D8 (resized).jpeg2DE54C41-E280-4860-B15B-24247FF3F0D8 (resized).jpeg
#19 3 years ago
You may want to look at your shooter lane before you go any farther.
#20 3 years ago
Quoted from Bryan_Kelly:
Yeah that could be a problem. No slot for the switch. Came like that from cpr.
4FC6DC73-DA6B-4030-B92F-0008AA7BD467 (resized).jpeg4FC6DC73-DA6B-4030-B92F-0008AA7BD467 (resized).jpeg
#21 3 years ago
Cutting the slot switch with a router, using excess oak rail wood as a guide. Set the guide up with a 3/16” gap and measured centerline in the shooter lane off the edge of the pf. Then set the wood at that distance. Clamped the wood down with c clamps to get a perfect cut. Put painters tape on the front side to protect the clear. Made my cut from the back side. I think we nailed it.
FB9F602E-C6B9-4E93-AC24-D6B3CBB69879 (resized).jpegFB9F602E-C6B9-4E93-AC24-D6B3CBB69879 (resized).jpegF5B19393-BC12-4E3D-B6BD-2BA7D2833EE5 (resized).jpegF5B19393-BC12-4E3D-B6BD-2BA7D2833EE5 (resized).jpeg97236622-073F-4CA5-B3B2-7D953B5268CB (resized).jpeg97236622-073F-4CA5-B3B2-7D953B5268CB (resized).jpeg0AEA1FEB-DD50-422A-8ACF-945C129778AA (resized).jpeg0AEA1FEB-DD50-422A-8ACF-945C129778AA (resized).jpeg83E4C210-BB24-406F-ABB8-932F36DD3D2D (resized).jpeg83E4C210-BB24-406F-ABB8-932F36DD3D2D (resized).jpeg
#22 3 years ago
Before and after.
69623383-85DA-4AF3-BEC7-01B5E3C55013 (resized).jpeg69623383-85DA-4AF3-BEC7-01B5E3C55013 (resized).jpeg0D5E5A01-5039-48BE-952E-A1E6B47A66C2 (resized).jpeg0D5E5A01-5039-48BE-952E-A1E6B47A66C2 (resized).jpeg
#23 3 years ago
Come on really?
#24 3 years ago
Hi! Nice job! May I ask where did you buy new playfield?
#25 3 years ago
And do you have plans for old playfield?
#26 3 years ago
Quoted from FlashBFD:
It came from CPR.
#27 3 years ago
Playfield was from cpr. I will be selling the old playfield once I’m done with it probably through pinside.
#28 3 years ago
Pop bumper gi going back in. Clear plastic tubing used to protect from shorts in areas with close proximity to other metal parts. Stapled in with T50 1/4” staples.
714A0B5C-A478-4A50-AC57-486B7CD73340 (resized).jpeg714A0B5C-A478-4A50-AC57-486B7CD73340 (resized).jpeg97899988-3939-4F66-87A5-C8BB786F5279 (resized).jpeg97899988-3939-4F66-87A5-C8BB786F5279 (resized).jpegE4967EB1-506D-40E3-B404-0665C2005360 (resized).jpegE4967EB1-506D-40E3-B404-0665C2005360 (resized).jpegE2AC1748-4CD3-4892-A86A-06A5904EA5FF (resized).jpegE2AC1748-4CD3-4892-A86A-06A5904EA5FF (resized).jpeg
#29 3 years ago
All mechanisms torn down cleaned tumbled and rebuilt with new parts as needed.
41FAA56C-0448-42D0-A3BD-73A37D23559E (resized).jpeg41FAA56C-0448-42D0-A3BD-73A37D23559E (resized).jpeg117A8B58-2552-4EBD-AA56-9EA6A6FDF690 (resized).jpeg117A8B58-2552-4EBD-AA56-9EA6A6FDF690 (resized).jpeg729F37A6-DCE0-49F6-B4A8-156703BAE6FD (resized).jpeg729F37A6-DCE0-49F6-B4A8-156703BAE6FD (resized).jpeg54583DDA-C3D1-4B33-910D-127BDD0C43B1 (resized).jpeg54583DDA-C3D1-4B33-910D-127BDD0C43B1 (resized).jpegimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#30 3 years ago
Daisy chaining through a three pin connector -- good idea!
#31 3 years ago
I repair electric motors for a living. When we tear down a motor,if it isn't blown up and needs rewinding but has been corroded inside due to water penetration or people pumping grease into worn-out bearings we will do a "wash and bake". We will take the stator and wash it in the parts washer. Then we thoroughly rinse the stator with fresh water to get soap residue and dirty water out of the winding. After that, we bake it in a large oven for 3-4 hours. Smaller stators take less time. It's essentially what people are doing with the dishwasher beside the baking at the end.
#32 3 years ago
Flippers rebuilt with new parts including eos switch and capacitor after cleaning and tumbling brackets. Return springs converted to wpc style per vid1900 recommendations by drilling a hole in the bracket to mount the spring beside the eos switch. Gets the spring off of the coil plunger preventing wear and making them feel snappier.
Rebuilt flipper with wpc conversion beside old system 11 style with conical spring.
8CD01AD3-75EE-4F70-88BD-3056364491FD (resized).jpeg8CD01AD3-75EE-4F70-88BD-3056364491FD (resized).jpeg
#33 3 years ago
Smart move!
#34 3 years ago
Switch harness reinstalled. Lamp harness will be next then finally solenoid and flasher harness. Solenoid harness is much easier to work with last since all the solenoids were put on molex quick connectors and can be installed or removed separate from the harness.
111B4633-DA3E-4538-A01A-6C9465153432 (resized).jpeg111B4633-DA3E-4538-A01A-6C9465153432 (resized).jpeg286684A3-6251-43C1-90E4-2AE72AF1622B (resized).jpeg286684A3-6251-43C1-90E4-2AE72AF1622B (resized).jpeg46109C9B-9719-4C57-A4B4-5E45EDC0D82A (resized).jpeg46109C9B-9719-4C57-A4B4-5E45EDC0D82A (resized).jpeg
#35 3 years ago
Lighting harness reinstalled. Pop bumper lights soldered in. Led conversion complete. All new twist sockets.
4A3FA163-5254-433C-8915-64B17C3DEC78 (resized).jpeg4A3FA163-5254-433C-8915-64B17C3DEC78 (resized).jpeg7D5414DE-158D-44DD-9C0C-B7A5EE7053D7 (resized).jpeg7D5414DE-158D-44DD-9C0C-B7A5EE7053D7 (resized).jpegAB0C82B6-A683-4087-86B2-7E0CB9A7161E (resized).jpegAB0C82B6-A683-4087-86B2-7E0CB9A7161E (resized).jpeg1D8BA847-AAD0-439D-BDA3-34DDFBD15022 (resized).jpeg1D8BA847-AAD0-439D-BDA3-34DDFBD15022 (resized).jpeg3887101E-C23F-4A9B-95A8-84FF0E5E79F8 (resized).jpeg3887101E-C23F-4A9B-95A8-84FF0E5E79F8 (resized).jpeg
#36 3 years ago
How did you keep track of where the wires went during re-install. I have done it with just labeling the wires with tape but that doesn't work if you put it through the dishwasher. Are you just using wire colors? Pictures?
#37 3 years ago
Looking good.
Interesting choice for pop bumper skirts.
#38 3 years ago
I took pictures during each phase of teardown. Removed all mechanisms / coils first. All coils had molex connectors installed and I labeled each end of molex plugs. Then more pictures after each wiring harness came off.
Putting wiring harness back on I didn’t need many pictures to reference really. The wiring has memory and just laying it out puts most things by where they will end up going. Pop bumper area was what I referred to photos most to get layout correct soldering in new connections.
#39 3 years ago
I see, I thought maybe after the dishwasher the harness wouldn't lay back down in the same way but it sounds like that is not the case.
#40 3 years ago
First start up test. 2-3 lights out just loose connections I’ll fix. Two micro switches not working will probably replace them. Overall I’m happy with it.
266EC314-6896-4688-8185-BED292E3E5C4 (resized).jpeg266EC314-6896-4688-8185-BED292E3E5C4 (resized).jpegBE52945A-1311-4285-9A53-D81342F7081F (resized).jpegBE52945A-1311-4285-9A53-D81342F7081F (resized).jpeg
#41 3 years ago
My ramp flaps look rusty so it’s time to make new ones. This will be my first time. Traced original then used some good scissors to cut it out.
Used titanium drill bit to drill smaller holes. Larger 1/4” holes wouldn’t cleanly cut and bit would tear the metal as drill went through.
I went and got a harbor freight punch set. This time I punched holes before cutting out ramp flap. I bought tin snips at harbor freight also. Much easier to cut metal and doesn’t trash your regular scissors. After cutting ramp flap I smoothed and deburred edges on a bench grinder I have.
B6A72B5F-3959-4B8E-90C6-B25C802F5567 (resized).jpegB6A72B5F-3959-4B8E-90C6-B25C802F5567 (resized).jpeg125B01BF-33E3-44F9-9C3A-09C1D296D663 (resized).jpeg125B01BF-33E3-44F9-9C3A-09C1D296D663 (resized).jpeg3FF412E6-9650-43F3-8B27-34E446460CD8 (resized).jpeg3FF412E6-9650-43F3-8B27-34E446460CD8 (resized).jpeg2333785A-4515-4E77-BEAD-005AAFB57EB9 (resized).jpeg2333785A-4515-4E77-BEAD-005AAFB57EB9 (resized).jpegF4CE8994-2F1F-4EB7-A707-46E7D6464FC3 (resized).jpegF4CE8994-2F1F-4EB7-A707-46E7D6464FC3 (resized).jpeg7BC64CE7-CC95-4B6E-BDDD-0F8B021D3B52 (resized).jpeg7BC64CE7-CC95-4B6E-BDDD-0F8B021D3B52 (resized).jpeg
#42 3 years ago
Old rusty lamp sockets tend to work intermittently and look like trash. So I replaced all of them. Controlled lamps need diodes, gi lamps don’t.
6D4CA668-5D4A-499C-B992-B2B35C46EE79 (resized).jpeg6D4CA668-5D4A-499C-B992-B2B35C46EE79 (resized).jpegBF0B59E5-27AD-4702-B151-6EAEA0101A05 (resized).jpegBF0B59E5-27AD-4702-B151-6EAEA0101A05 (resized).jpegE1461D7E-CA39-47B3-8408-8610F1F80B6F (resized).jpegE1461D7E-CA39-47B3-8408-8610F1F80B6F (resized).jpeg
2 months later
#43 2 years ago
Now that the weather is nice I’m finally refinishing the cabinet. Stripped the lower cabinet down to just ground braid.
1535CDB0-10BE-4E13-91BE-97FD4C8D1021 (resized).jpeg1535CDB0-10BE-4E13-91BE-97FD4C8D1021 (resized).jpeg28425AD3-EEA1-4776-9DD5-A951EF7A1EA6 (resized).jpeg28425AD3-EEA1-4776-9DD5-A951EF7A1EA6 (resized).jpeg55105855-CD35-4029-9AA9-B76424214E93 (resized).jpeg55105855-CD35-4029-9AA9-B76424214E93 (resized).jpegBDF5B225-831B-4DA9-B4E8-C316537E5AFF (resized).jpegBDF5B225-831B-4DA9-B4E8-C316537E5AFF (resized).jpeg
#44 2 years ago
After sanding the cabinet outside any gouges were filled in with floor leveling compound and then resanded. Williams serial number stickers were masked off. I found rustoleum 2x ultracover in brilliant blue to be a good match.
2B5891E9-727B-42AD-A4D8-7B44EE3D4E85 (resized).jpeg2B5891E9-727B-42AD-A4D8-7B44EE3D4E85 (resized).jpeg328CE1EC-7F7E-4BCA-8382-E5E07FF750C5 (resized).jpeg328CE1EC-7F7E-4BCA-8382-E5E07FF750C5 (resized).jpeg8FA3F2C6-EFE1-4908-B0ED-FDCBF1A29323 (resized).jpeg8FA3F2C6-EFE1-4908-B0ED-FDCBF1A29323 (resized).jpeg
#45 2 years ago
Head is coming along. Main cabinet has been stripped, sanded, painted, and next gen decals have been applied.
23475F6D-E1B2-44D4-BFB5-6E01561F0922 (resized).jpeg23475F6D-E1B2-44D4-BFB5-6E01561F0922 (resized).jpeg70606CEB-96B9-4524-BB6A-5078044D442A (resized).jpeg70606CEB-96B9-4524-BB6A-5078044D442A (resized).jpeg9B056EB7-1B82-4A7E-A584-3BF71F1D7EF2 (resized).jpeg9B056EB7-1B82-4A7E-A584-3BF71F1D7EF2 (resized).jpeg
Precision Pinball prod.
$ 12.50
RoyGBev Pinball
$ 899.00
$ 90.00
$ 54.99
Metal-Mods
$ 16.50
$ 45.95
$ 18.95
8,500 (OBO)
Bakersfield, CA
$ 399.00
$ 95.00
Pinball Mod Co.
Middletown, OH
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/whirlwind-complete-restoration and we tried optimising it for printing. Some page elements may have been deliberately hidden.
