I'm in the middle of my first flipper rebuild and I have a question that I haven't been able to find a related answer to. The included EOS leaf switch from the Marco kit has a very long arm that makes contact withe the back end of the tighten-down bolt instead of the insulated L arm. If I cut it shorter, I'll need to bend both arms toward the coil in order for the L arm to push the contacts far enough apart.
Is leaving it like it is a bad idea? Or do I just have the wrong leaf switches?
Quoted from GRUMPY:Yes, bad idea.
When you tightened the pinch bolt to hold the flipper in place, did you have any space between the bushing and the paw?
I used the spacer tool (fork) on top, which allows for a little play up and down if I pull the flipper from the top. I assume that's the intent.
I think I've got the first flipper rebuild done, it seems to work without issue.
I've also not seen any more phantom sweeping scores after re-flowing solder on both sides of the pin connector on the 3 bank opto board. Just a couple games tested though since I still have two more flippers to do. Should go faster next time.
