(Topic ID: 62621)
Whirlwind Club... Members Only!
By mof
6 years ago
  • 3,366 posts
  • 344 Pinsiders participating
  • Latest reply 4 days ago by Jr99svt
  • Topic is favorited by 164 Pinsiders
There have been 905 images uploaded to this topic. (View topic image gallery).
There are 3366 posts in this topic. You are on page 67 of 68.
#3301 83 days ago
Coil Strength... I have a toasted upper flipper coil. As I prepare to replace I have a question on the correct coil in that spot. The manual says both upper and lower right side flipper coils are FL-11630. What is there currently is FL-11753. This upper flipper is a bit weak, not sure if it is due to the slow death it has been suffering or underpowered coil. Suggestions? I don't want to overpower and smash a ramp. But underpowered has taken the entire upper ramp shot out of the game. FYI all other adjustments on the flipper assembly are correct. EOS, clean and tight switches, etc. This is definitely a coil issue.
Thanks, in advance.
#3302 83 days ago
I have 11630's on all three and I have no problem hitting any ramp with the playfield at 6.5°.
#3303 83 days ago
Quoted from tomm1963:
Thanks, in advance.
yup toss it, underpowered. 11630's is designed for the game.
#3304 75 days ago
Quoted from zerbam:
if your ball goes up the ramp when you plunge the ball......then your machine is adjusted wrong.....it should go to the right of the ramp and loop around to the upper right flipper.........there are many discussions and photos of how to adjust it in this thread
Could you maybe post a direct link?
Mine goes up the ramp every single time
#3305 75 days ago
see post #2511 or go to the top of this thread and search "ramp adjustment"
#3306 62 days ago
Have original used set from my whirlwind. 100$ for everything include shipping. Dm who interested
#3307 61 days ago
I am going to see if I can fix a Whirlwind display assembly for a friend. The display was working perfectly but recently the bottom display acts up. Whenever the b segment lights up the three segments k m n to the left light dimmly as well. Has anyone run into a similar issue? We did swap out the whole display board from another game which worked. That showed the MPU and cable should be ok and points to an issue on the display board.
Not sure if a piece of rouge solder got loose shorting out the segment lines, driver chip failing, or the display glass going bad.
I'll probably dig into it more over the next few evenings and was just checking on what the most likely problems to check first.
#3308 61 days ago
Quoted from vbobrusev:
just bought brand new for $140!
#3309 61 days ago
Quoted from Robotworkshop:
And there not available anymore.
#3310 61 days ago
I had some display issues a while back... maybe this is mildly helpful:
https://pinside.com/pinball/forum/topic/williams-system-11-score-diplay-issue-
#3311 43 days ago
Backboard LED lighting made a huge difference. Favorite all time pin. This may be my first long term pin.
#3312 42 days ago
Quoted from GRUMPY:
yea they are.
Obsolete? yes.
Mouser or Digikey? no.
But they are out there. Used my last Cathode driver last night. Purchased some this morning.
#3314 42 days ago
Quoted from Jr99svt:
The only thing I have found out there is counterfeits that explode when powered up causing more damage to the board. So I am using used board pulls until they are all gone.
#3315 42 days ago
Quoted from sataneatscheese:
Backboard LED lighting made a huge difference. Favorite all time pin. This may be my first long term pin.[quoted image]
Where'd you get that apron? Looks sweet.
#3316 42 days ago
Quoted from GRUMPY:
Its a crapshoot from China. More than likely their obsolete "new" items are cleaned up pulls, more often than not. Ive been lucky, havent had an issue with ICs from China, yet....
#3317 42 days ago
My game is not at home as of now. But need to order a new pc of glass for my back glass does anyone know the measurements of it. And is it 5 mm same as pf glass.
#3318 42 days ago
Quoted from Twilight1:
Hope this link helps!
https://www.pinwiki.com/wiki/index.php?title=General#Backglass_Sizes
#3319 42 days ago
Wow thanks that helps a lot. Didn’t even think to see if there was a date base for this info.
#3320 42 days ago
Quoted from Pinball_Gizzard:
https://www.tiltgraphicsinc.com/whirlwind
Magnetic and removable.
#3321 42 days ago
That's very cool. Might have to think about that one as my next birthday present or something.
#3322 25 days ago
Finally nailed the 3 way combo tonight
#3323 25 days ago
Anyone have a whirlwind spinner for sale or know where to find one? I have what I think is a decent replacement enroute, but I'd prefer the original.
#3324 25 days ago
Greetings,
If you follow the TAF owner's thread by chance then you would have seen that I created a light board for the "THING" lamps that allow you to fit a ColorDMD LCD over top of them. I see that perhaps Whirlwind has the same board (D-12501 / 5768-12377-00 Rev A)? I do not own a Whirlwind but I am willing to create one of these boards for this machine if you guys want me to. I realize you don't have a ColorDMD to install and worry about, but perhaps your current board is missing or broken and you would like a replacement. Below you can find all the photos of the one I created for TAF. It fits flush with a black colored board to prevent any light from leaking through. I am producing two versions, one with Warm White 3000K leds and one with Cool White 5700K ones. The photos below show the Warm White version. I did tweak the shape from the ones shown to allow an easy plug and play installation even if you have a set of flipper fidelity or pinball pro speakers without having to remove them. There is some slight ghosting but it ins't very bad IMO. If you have one of the OCD LED boards installed it should eliminate any ghosting although I do not have one to test that theory.
I am estimating them to be in stock by the end of February, and should only be around $10-$20 ea plus shipping as I am not looking to make anything off them, just wanting to help others out.
Anyways, if you want one please PM me with the following:
-Subject: Earthshaker Light Board
-Full Mailing Address
-# of boards wanted
-Paypal Email Address
Once the boards are in production I will send you a paypal invoice for payment along with the total amount shipped. Any extras from the batch order will also go on my pinside shop if you prefer to wait until then. I do plan to keep these in stock as long as there is a demand for them so no worries on "Missing Out" from any kind of one time order.
Best Regards,
Robert Goebel
Pinshakers
www.pinshakers.com
Photo Jan 19, 6 49 11 PM (resized).jpgPhoto Jan 19, 6 49 21 PM (resized).jpgPhoto Jan 19, 6 50 04 PM (resized).jpgPhoto Jan 19, 7 05 09 PM (resized).jpgPhoto Jan 19, 7 11 16 PM (resized).jpgPhoto Jan 19, 7 11 27 PM (resized).jpgPhoto Jan 19, 7 26 12 PM (resized).jpg
#3325 25 days ago
Quoted from robgo777:
Greetings,
-# of boards wanted
Best Regards,
Robert Goebel
Pinshakers
www.pinshakers.com[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Interest may increase with the Whirlwind software rewrite project moving again...
#3326 25 days ago
Oh yes. Prepare to be very excited.
#3327 25 days ago
Quoted from Sciddleybop1980:
Oh yes. Prepare to be very excited.[quoted image]
What?what!what?!?!?!
#3328 25 days ago
YEAH, WTF !?!?
That looks sweet
#3329 25 days ago
Mypinballs started a rule rewrite using PRoc years ago. It was always written around using the existing alpha numeric display. It took a sabbatical for a while but looks like it’s back and with dots!!! Haven’t been this excited since Christmas 87
#3330 25 days ago
Omg. How much is this gonna cost me?!
#3331 25 days ago
Most excellent news!
#3332 25 days ago
I see prices on Whirlwind trending up... how much were the BOP 2.0 kits when they were made?
#3333 25 days ago
2k
#3334 25 days ago
Well..... If that's the case, I guess it won't cost me a thing
#3335 25 days ago
Can anyone offer more info?? After I finish off my Quicksilver resto, my Whirlwind will be next, anything to make it an even better game excites me greatly!!
#3337 22 days ago
Does anyone have a list of the speech phrases from Whirlwind?
-1
#3338 22 days ago
Yes it's;
'Oh maaannn...'
And then ist say's ;
'Oh maaannn...'
And then it's;
'Oh maaannn...'
#3339 22 days ago
Quoted from punkin:
Yes it's;
'Oh maaannn...'
'Oh maaannn...'
And then it's;
'Oh maaannn...'
Thanks.
Anyone else? Considering buying, but wanted to know what I'm actually hearing in videos.
#3340 22 days ago
From memory it’s
“Uh oh, looks like rain!”
“Oooo Million!”
“Feel the power of the wind!”
“Here it comes!” (At the start of multiball)
“No storm now, go away!” (When entering the cellar unlit)
“Now, get out!” (Also when entering the cellar unlit)
Whirlwind!” (At the start of cellar multiball)
“Feel the power!” (When collecting millions plus)
The last one puzzles me. It’s only heard when collecting the mega door bonus and it sounds like “Hey hey, crikey!” Like an exuberant Australian.
There may be more I’m missing, but those are the call outs you’ll hear most often.
#3341 22 days ago
Quoted from mbaumle:
From memory it’s
“Oooo Million!”
I think you're right about the "crikey" bit. The hillbilly accent's a bit thick on that one. But you forgot, at the end of the Mega-Door bonus "thunderstorm" he also says "Ya'll come back now!" Also "Head for the cellar!" as a hurry-up.
Worth noting the "Whirl-Wind!" and "Feel the Power" are in a sinister baritone which is pretty awesome. Like a Black Knight cameo
Edit to add (duh, headslap!)
Storm chaser over P. A. : "The storm is coming, return to your homes!" ; "all clear!" ; "do not panic!"
#3342 22 days ago
is there a female voice that says something over and over?
#3343 22 days ago
Do not panic
#3344 21 days ago
Welelelll lookie here!
#3345 21 days ago
I forgot a ton! Didn’t realize there were so many more.
The deep baritone “whirlwind” and “feel the power” are some of the most adrenaline inducing call outs. Nailing that millions plus jackpot and hearing feel the power with the lighting bolt effect is one of the most satisfying jackpot collects.
Quoted from canoncitypb:
Only when the million shot is lit via a cellar door bonus or during quick mulitball. She just says “oooo Million!” Every so often until it’s collected, multiball ends, or the ball drains.
#3346 21 days ago
'I'm getting changed'
#3347 21 days ago
I always thought it was something along the lines of "cracky/crackie". Short for crackshot?!?!?
#3348 21 days ago
That is what I was hearing. Sounded pretty annoying.
#3349 20 days ago
Quoted from goingincirclez:
That’s why I have a speaker upgrade heading into mine to get that great depth for the “Feel the power!!!” & “WhirlWind” call outs. Going to sound unreal!!
#3350 20 days ago
Quoted from northerndude:
Keep us posted about that, be interesting to see how much improvement there is.
$ 399.95
Pin Stadium Pinball LEDs
$ 839.00
PinWoofer
$ 99.00
Pinball Sales
$ 369.00
