Awesome gameplay man!!!
Quoted from orangegsx:
Trying out a new camera setup to get videos of gameplay. Made a short clip of a whirlwind multi ball run tonight.
Some good skills there bro!!
Quoted from northerndude:
Quoted from Flynnyfalcon:
Thanks, only game I am good at. I should have been punished for missing the shot to the saucer over and over though haha.
Quoted from GRUMPY:
Replace these parts, Q-4, Q-5, D-15 and D-16.
Alright replaced all of these on the Aux board which fixed the kick out coil, but the ball divertor coil is still stuck on.. Must be something on the driverboard, but I did already replace the transistor for it.. Any suggestions? Thanks!
Quoted from Elicash:
Hi guys I am considering restoring a barn find WW. Will need a new cab and play field. My question for you all -
What parts are impossible to find or replace?
I think all the metal parts are salvageable but wondering what I am up against.
Thanks for feedback.
Do you have a thread you could link to? I'd love to watch that process. I would guess the topper might be tough, but I think recently those have been linked to for sale. So maybe nothing is all that hard to find, at least I hope that is the case.
I’m in! Found a Whirlwind about 6 hours away, tracked it down from someone mentioning they thought they had heard of a Whirlwind in a pizza parlor years ago in Kingsville, Texas (near the coast in south Texas). So I called all the pizza places in Kingsville and eventually found the machine in a warehouse in Kingsville. The machine is not currently working, just says “Failure” when turned on. I saw some burnt connectors on the interconnect board and the batteries were pretty crusty so I removed them and will be treating the area with the vinegar and water method. Playfield looks good, everything seems to be there. There are a few broken plastics. Cab is in good shape, topper is there but base has some cracks and it is yellowed. Will restore that for sure.
Anyhow, had to drive about 900 miles round trip but I’m in and got it for a great price!
Quoted from desertT1:
Good to know Topper is hard to find. This one will definitely need to be replaced. What about the spinning discs mechanism? I know you can get the little rough disc pads themselves, but what about mech? The one in my game may be okay, but I have not dug into it yet.
I will definitely start a restoration thread if I move forward. Thanks for the interest. It is a pretty sad looking game. Major water damage, rust, etc.
I was able to get power supply board and MPU board working, so that was a huge first step. Using my Taxi as a test fixture since both are system 11B's.
Quoted from Pinball_Gizzard:
any ideas on this Failure message?
Adjust Failure = Dead batteries.
Quoted from GRUMPY:
Or a bad battery holder, make sure the battery voltage is reaching the board.
Ok first question, any ideas on this Failure message? Left display is garbled, right says Failure. I replaced batteries with fresh ones so it isn’t dead batteries. Where to start?
Bad battery holder, you will need to replace it with a battery pack.
Or corrosion under the battery holder, mine showed the same thing when the roms had been erased after some chip issues
Quoted from pacman11:
If I go with NVRAM do I still need the batteries?
Or both. Dead batteries that have leaked their alkaline down to U41 and surroundings to interfere with display data lines.
Ok I’ll work on cleaning the board and neutralizing the alkaline first and go from there. I always NVRAM my games so I’d rather not replace a battery holder I’m not going to use.
Nope, you won’t need batteries then..
Agreed! Looks like its dialed in nicely too
Update- After checking Q15 on my driverboard it appears to be testing as a good transistor. I didn't have a tip122 so I use a tip121 to replace Q15 last week. I am still having issues with diverter coil still staying on. I changed the coil with a new one too. I swap in a brand new rotten dog Aux power board so I don't believe my issue is there anymore.. Any thoughts? Could it be that predriver transistor to Q15, if so what size are those?
COuld be, or your driver wire, could be bare and shorted to ground somewhere on the playfield, too.
Assuming you checked this, by disconnecting the connector that supplies the driver wire to the coil while leaving the power connector connected? (Sorry, don't know the J-numbers offhand..)
I'm at work right now so I can't say if this is a good replacement. I would have used a TIP102 in place of the TIP122.
Quoted from scampcamp:
I’m checking out some titan competition rubber colors & am trying to figure out what would look good.
What colors have you guys chosen?
I may go with white for the rings & do light blue for the flippers & posts.
I did all light blue silicones with translucent slings. My setup is in the whirlwind section on the titan site.
Quoted from GRUMPY:
I did look it up. TIP120, TIP121 and TIP122 are all NPN configuration. Funny those comparable transistors are out there. Never heard of them until now. Replacing any TIP122 with a TIP 102 was one of the first things I learned. I know for a fact that I have never purchased a TIP122.
Go into adjustment menu and “restore factory settings” then exit adjustment menu.. see if that works.
Quoted from Blitzburgh99:
I can't get into the adjustment menu. The game dings when you turn it on, display is blank. Then about a minute later the error message comes up. GI lights up but nothing else is happening.
I did notice the diagnostics light is blinking steadily, not blinking out out a specific number as it says in the manual. Also the LED labeled Blanking is not lit at all. It does flash at the same rate as the error message on the screen when the error message is flashing. I was under the impression this light was supposed to be lit all the time but maybe it doesn't light because the CPU isn't booted yet?
Update- Aright something is going on, on the new rottendog Aux power board u5 36c large transistor got smoking hot and almost fell out of the board.
The cellar kickback coil is locked on. How big is F-4 fuse?
Pulled the main board out and did the vinegar/water/alcohol treatment today. Looks better I think, I didn’t see anything that looked like corrosion under the mask on the front side. On the back there are some traces that the mask has come off off but they still look ok. I assume I should paint some solder mask back over these areas?
Also are there any areas you guys see that need further attention while I have the board out?
Probably just the photo, but is pin 1 on U24 in the socket?
Quoted from Freeplay40:
Good catch, thanks!
So I’m finally working on the last two issues on my game. The first one is that I have now bought two springs from two different places and I still can’t get the ball to go all the way back around to the flipper. It seems kind of odd - the first I bought was from bay area amusements and it seemed week the second spring from Marco is also seeming kind of weak, it only good gets it up to the bumpers and I’m wondering if it’s the spring or is it the lane guide? Somebody told me I might need a certain kind of spring? Advice?
The other issue is that my spinner is not registering. I got a brand new switch and the switch works perfectly if I touch it but the action of the spinner is not making the switch engage. Does anyone have any advice on this and could people please post pictures of their spinner and underneath how the switch is connected to the spinner? I’m wondering if I’m missing a part?
Quoted from yzfguy:
My LEDs do not do this. I don't think anyone has added any diodes. Could it be the brand/type of led?
I was wrong...... Just notice today that the flashers do give a brief half flash when I press the flippers. I can't believe I never noticed it, but now I can't unsee it!
Quoted from yzfguy:
You just reminded me of my inability to unsee interlaced video displayed on a progressive device.
https://pinside.com/pinball/forum/topic/adding-led-flashers-to-system-11-games
Quoted from DumbAss:
Holy hell..... I'm thinking I just live with the flicker, or put in incandescents if it really bugs me
Hi there guys,
I'm wondering if anyone could provide me with a photo of how the lower switch on the upper ramp is wired? Maybe a photo of the connector under the playfield for this switch too?
I just finished a restoration on a whirlwind and this is the last issue to fix before it's done! For some reason the switch was missing when I bought the game.
Greetings all! I will have a "restoration post" shortly on the filthy, disgusting, mylar peeling planked inserts raised and lowered and barely working project I'm wrapping up. But first...
Has anyone upgraded their speakers to something commonly available recently? I am looking for the backbox speakers, and before I get sucked into hours of research, has anyone found anything that isn't $150+ pinsound, but will go (mostly) plug and play with WW? I'm not opposed to the work, but when I started down these threads, there are just too many options and I'm short on time.
I'm looking for actual product SKUs you've bought that'll work. "Hey Dumbass, buy this and this and this" appreciated!
Ok follow up question. The Whirlwind I bought is having what I believe is an adjust failure however the first display is putting out garbled letters so it doesn't say "adjust" or anything that I can make sense of. I pulled the battery holder off the board (it was corroded) and treated the board with vinegar/water/alcohol. I had NVRAM installed on the machine today and the same error is still happening. Any ideas on where to go next?
Quoted from yaksplat:
Anyone compare the quality of the Mirco and CPR playfields?
Both company’s playfields are excellent quality.
Quoted from yzfguy:
I put the incandescnets back it. The flicker annoyed me
I had the same problem with my Game Show, I thought it was a bad display at first, but my board was corroded enough that needed replacement. I bought a new sys11 bird and first time I fired it up the display was mint.
Maybe send it out for repair ?
Usually corrosion at the PIA chips, the SIP resistors near the display header or traces running between those. Had the same thing on my Whirlwind and had to clean it all up... though if it's really bad it might be difficult to make "reliable" without a bunch of jumpers and hacks.
Your pics didn't seem to bad though. Could be something conductive at the PIA that was replaced.. the flux, or something hiding under the socket. Could also be a bad PIA chip too, I'd probably try replacing the one that's in the socket as the first measure... if it corresponds to the affected alphanumeric digits.
Quoted from plankalkul:
I went with these for the small right side one and the cabinet speaker. At this point I still have the left side speaker panel one in place. If I was to match the right side I would buy a Boss BRS46. Certainly a good bang for the buck option.
Have (m)any of you installed a cpr backglass? If so, can you suggest a good backbox led setup to better light it up?
Quoted from bailorgana:
self bump - what do you guys think?
I found it to be a combination of the adjustment at the shooter lane exit and the proper spring (green worked best for me).
Is the plunger tip square with the ball? The housing can be adjusted by loosening the three screws inside.
If yes to above... is there a divot that keeps the ball from resting against the plunger tip? Are the metal tabs on the shooter lane gauge set properly? They might need to be slightly bent towards the front of the machine.
A picture of the ball in the shooter lane that also shows the plunger tip might yield additional feedback.
