(Topic ID: 62621)
Whirlwind Club... Members Only!
By mof
6 years ago
  • 3,739 posts
  • 368 Pinsiders participating
  • Latest reply 6 days ago by yaksplat
  • Topic is favorited by 173 Pinsiders
There have been 1,056 images uploaded to this topic. (View topic image gallery).
There are 3739 posts in this topic. You are on page 50 of 75.
#2451 1 year ago
Hate to do it, but I have to leave the club. I just put my very nice WW on the marketplace for $2850 OBO. I’m located in Southern California
#2452 1 year ago
Quoted from ccbiggsoo7:
how do you replace rivets? what kind of press?
To do it correctly, you need the "tubular rivets". I purchased a bunch from Hanson Rivet about a year ago:
https://www.hansonrivet.com/rivets/tubular-rivets/
5/32: TBC0805N or MS20450-C8-B5N
3/16: TBC0806N or MS20450-C8-B6N
7/32: TBC0807N or MS20450-C8-B7N
1/4: TBC0808N or MS20450-C8-B8N
9/32: TBC0809N or MS20450-C8-B9N
.133 X .312 X .032 washers: WS-0810
Those are the same chome/nickle plated brass rivets originally found in our pins. I had to call Hanson Rivet directly and give them the part numbers to place my order, wasn't able to do it over the web site. I ordered like 100 each item. I also got a tool, "HT-174" rivet clincher:
http://www.erivet.com/product_detail.cfm?itemNbr=HT-174
But I've never used that tool... a friend of mine has a manual press tool that provides great control and also makes doing the rivets a 1 person job.
Doing the actual riveting itself is simple... drill out the old rivets. Get your parts stacked up and fit in your replacement rivet... you want it to just poke through, or at least I went with the shortest rivet that was longer than the stacked material. Blue tape on the head of the rivet to hold in place and protect it, so tube side of the rivet was up, put in the press and mash it down.
#2453 1 year ago
Cant find switch 5647-12073-08 Ball through #3 (right) any leads?
#2454 1 year ago
Quoted from jkashani:
Is it just a regular microswitch? If so, get anything and pop the tab off the old one and put it on the new one.
#2455 1 year ago
Update on the switch issue. I lifted the playfield to change the switches and the first switch was getting stuck. I bent it back and it seems to have fixed the problem.
#2457 1 year ago
Over a thousand plays since I finished freshening this thing back up, everything is still running smooth. Loved this game since I was a kid. My boy loves it too.
B37682C5-08B8-4C14-843A-2584EA9C3027 (resized).jpegFB6B0495-B06D-482D-B10D-1A27EF4FD95D (resized).jpeg
#2458 1 year ago
I put LED flashers in tonight. When I hit the left flipper, the lowest left flasher “ghosts” everytime. I have all of the OCD boards en route. Will this fix that issue, or do I have something that I need to investigate further?
#2460 1 year ago
What LED bulbs work best for the flashers in the backbox?
#2461 1 year ago
Quoted from Blitzburgh99:
I've been sticking with kits from Coin Taker. If you go to replace the control lamps, get the non ghosting type.
#2462 1 year ago
98 skyway tolls on ball 3 and I drain Never been that close to the end...
#2463 1 year ago
Quoted from pencilneck:
Cointaker makes some great kits! This go around, I used the list someone posted in this thead (pretty sure) and ordered from Comet.
Just trying to figure out what the bulbs are for the flashers in backbox as they are smaller round bulbs that I haven’t experienced before.
#2464 1 year ago
Are you talking about the 545 blinking bulbs?
#2465 1 year ago
Quoted from gutz:
Keep trying! The sound is neat. But not as cool as the three way combo..
I did the same thing on my buddies earth shaker 98 miles and a ball 3 drain
#2466 1 year ago
Quoted from zene10:
Yes. the ball shaped ones that blink. 6 of them.
#2467 1 year ago
Where is best place to get plastic protectors? I bought the pinbits set, but the sling plastics are huge and stick way out from the plastic. Don’t like the way they look.
#2468 1 year ago
To cliffy or not? I have the full set of cliffy’s and the two cellar holes are very minimally worn (HUO game). Will the cliffys cause more damage than prevent? In other games, the cliffys make the shots harder to hit. What about on Whirlwind? Any playing difference?
#2469 1 year ago
Got a Whirlwind recently.
#2470 1 year ago
I bought the set from playfield protectors in germany and they are exactly the same size as the cpr plastics
#2471 1 year ago
I would leave them off unless the wear gets really bad personally. With that said, I had them on mine which was similar as you and although they lifted slightly, they didn't affect the ball travel (at least I never noticed a difference).
#2472 1 year ago
Zero difference in gameplay for mine. I thought since there was that small raise in height it would make a difference, but no.
I needed cliffys on mine since it was a CPR replacement and the clear has chipped away at the cellar entrance. I had pics posted a ways back.
#2473 1 year ago
Ok...OCD boards for the inserts and GI. I’ve heard that the only way to replicate the fade of incandescent bulbs when changing over to LEDs is by installing the OCD boards. Now I have one of my best techs telling me not to install them...that it’s just one more thing that could cause game issues. What are pros and cons when it comes to Whirlwind?
#2474 1 year ago
IMO LedOcd is only needed in games that had the bulbs "fade" as a feature. Games like Hook. Not needed in Whirlwind as far as I can tell. Just use Non-Ghosting in the inserts and they look great.
#2475 1 year ago
Quoted from hailrazer:
I think just the fact that the LEDs instantly turn on and off is what he is talking about. Incandescents have that quick but gradual fade, that I kind of miss
#2476 1 year ago
The inserts OCD looks to be plug and play. The GI one requires a number of modifications. I’m not sure I want to start hacking on my game if the effects aren’t worth it.
#2477 1 year ago
Shop out eye candy!
05638746-75B5-4F22-8A1C-B8A924B5A04D (resized).jpeg2A10608B-BF90-46DE-91D7-203B0892FF45 (resized).jpeg2E8009F7-03C2-462F-95F2-D213EACC5AFF (resized).jpeg
#2478 1 year ago
Hoping to get back to my Whirlwind. Does anyone have a repro topper that they would want to part with?
#2479 1 year ago
Quoted from orangegsx:
I've been to the end of the road on ES several times, but never even close on WW (besides this time). Not sure why, the main ramp shot is almost identical!
#2480 1 year ago
Quoted from gutz:
Does your left flipper have ball hop? Both the original playfield and my replacement playfield, the positioning of the left flipper creates a gap on from the return lane and thus ball hop. Shots off the left flipper are hard to be consistent with.
#2481 1 year ago
Haven't spent much time on this yet. The top row of the display is out. Bottom works fine.
Anyone else seen this?
#2482 1 year ago
I have a small amount on the left flipper. Tried everything to get rid of it.
#2483 1 year ago
I think Cliffy has some repro lane guides that helps reduce or eliminate ball hop here:
http://passionforpinball.com/FlipFrames.htm
Moving the flipper assembly a little may help as well.
#2484 1 year ago
Quoted from John_In_WI:
https://pinside.com/pinball/forum/topic/williams-system-11-score-diplay-issue-
My Earthshaker had a display issue, wasn't the ribbon cable. Resoldered the headers and that fixed my issue.
#2485 1 year ago
#2486 1 year ago
Absolutely I have left lane ball hop, frustrating!
I have put a toothpick inside the screw hole in PF to wedge the screw over a bit to eliminate, it works fantastic for a while, then slowly migrated back to original position. Hard to get into ramp rhythm when the ball hop is there.
#2487 1 year ago
That looks like a ribbon cable issue
#2488 1 year ago
Could someone confirm the fuse value on the triac driver board mounted to the top of the head for the blower motor? My manual says 1amp but a sticker next to it says 5amp. I believe it should be 5amp (thats what was in my board before i fixed it and rebuilt the power supply). 1amp blows when storm starts, 5amp everything runs great. I didnt find anything on IPDB as an addendum for this.
#2489 1 year ago
5ASB = 5 Amp Slow Blow
#2490 1 year ago
So, i've been working thru a few problems on my machine and came across this green wire that has come off. I'm also having an error with the ramp lifting mechanism. Any ideas where this green wire attaches to. i'm thinking to this coil but just want to double check.
thanks
#2491 1 year ago
Yeah thats what it says - just the manual states 1amp so wanted to confirm what it should be...
#2492 1 year ago
Quoted from Flip-it:
DO NOT connect this to a coil. It goes to a switch, most likely the switch under the coil.
#2493 1 year ago
Great advice. See which of these is missing from a switch. Note that there may be one already attached as it loops through. Likely ramp down?
#2494 1 year ago
so when i took a closer look, it came off a standup target by the ramp. Soldered it and the ramp is moving up and down again. Hadn't played in months but managed a respectable score on my second game.
#2495 1 year ago
Aright my Whirlwind just developed an issue. Both coils pull in when turned on. Is there one transistor that controls both of these coils or something? Coil 13 looked fired to me so I replaced it with a new one already. Problem coils are numbers 13 & 14
#2496 1 year ago
Should have the list in the manual. I’m dealing with same thing on my Game Show. I’m waiting for a replacement transistor from mouser. The sling locks on the second the pin is turned on.
#2497 1 year ago
Quoted from northerndude:
Yeah as soon as you turn it on they both lock on.. I see what two transistors control these coil just think it’s strange they would both go at the same time.
#2498 1 year ago
Quoted from pacman11:
Pull out your Aux power board and check your transistors and diodes on-board. If you don’t know how to test (I didn’t) just YouTube “testing a transistor” and it’ll spell it out for you. I found the bad transistor instantly.
#2499 1 year ago
Switch out the power aux and put a new one in and now it’s working great. Now I’ve just got to figure out which transistor is responsible for those coils.
#2500 1 year ago
Full LED with LED OCD on the inserts and PDI glass installed. Also put color cliffy posts in. What a beautiful game!
$ 839.00
3,300 (Firm)
Matthews, NC
$ 54.99
$ 16.50
3,400
San Diego, CA
$ 369.00
