(Topic ID: 62621)
Whirlwind Club... Members Only!
By mof
6 years ago
  • 3,049 posts
  • 329 Pinsiders participating
  • Latest reply 11 hours ago by granolapunk
  • Topic is favorited by 154 Pinsiders
There have been 826 images uploaded to this topic. (View topic image gallery).
DSCN4234 (resized).jpg (© Nutty 5.0)
DSCN4646 (resized).JPG (© Nutty 5.0)
There are 3049 posts in this topic. You are on page 5 of 61.
#201 5 years ago
Quoted from swenny:
Quick Q for other WW owners. Does the ball come out of the cellar on your game at a consistent speed? Mine seems to be all over the place. Sometimes when it ejects it comes flying straight down towards the flipper. Other times it kind of dribbles out, hits the top of the triangular bumper below it and then takes a funny angle to the drain hole. It's definitely not consistent.
Is the game supposed to be that way, or is the solenoid weak and in need of repair? I've never played another WW before to know if they're all that way or not.
Thanks,
Swenny
Mine varies a bit, and I consider it to be normal. I replaced the coil and coil sleeve, adjusted the angle of the assembly, etc. I did eventually find a good spot that generally delivers the ball where I want it. It just takes some tweaking. If it is just dribbling out of the scoop, you might want to inspect the assembly, coil sleeve, and the scoop itself. If the scoop weld is broken, it could cause some issues with ejects.
#202 5 years ago
Double post.
#203 5 years ago
I did a good cleaning on my ww Christmas Eve.
I had not cleaned it for over a month. I know, I've been really busy with work, family etc. any way, it's playing faster than ever and looks great. I am never selling it.
Even if it is my only game I ever have.
#204 5 years ago
Quoted from swenny:
Thanks,
Swenny
Mostly same for me.
-mof
#205 5 years ago
Quoted from swenny:
Thanks,
Swenny
I've had the same issue. I've read it's somewhat common.
#206 5 years ago
Quoted from swenny:
Thanks,
Swenny
When I first got mine, I had this problem. I replaced the coil sleeve, return spring, buffed the plunger, cleaned the passage, and made sure everything was mounted nice and tight. I've had zero issues since then, unless 2 balls are down there.
#207 5 years ago
Quoted from dsuperbee:
I did the exact same.
No problems since.
#208 5 years ago
Quoted from swenny:
Mine is consistent with very little variety. Sounds like your plunger could be binding in your coil sleeve.
EDIT: oops saw was on page 4 of 5 didn't realize there had already been so many answers
#209 5 years ago
Has anyone else noticed there are a lot of whirlwind games for sale? There have been several here lately and currently there are 3 near me for sale. The ones near me they want too much for so they are going to sit for a while.
The people who are selling are most likely going to miss them when they are gone.
#210 5 years ago
the old ass kicker. that's what my dad is calling whirlwind now. after the good cleaning she seems to be playing faster and meaner than ever.
#211 5 years ago
Here's my January entry...now get out!! Seriously, I hit the mega door bonus twice and couldn't hit the left ramp for crap!
#212 5 years ago
That's a pretty good score.I've been trying to hit that twice and have not been successful.
#213 5 years ago
Just got mine working again. It's almost time to shop it out and clean it up
#214 5 years ago
Quoted from jhanley:
WW is such a brutal game. It destroys me quite often. That game I was focusing mostly on ball control. There are a few key shots when getting high scores on whirlwind.
-Make the cellar door from either flipper on command. I am very good at making this shot. Every time it lit I nailed it. (ie. The right inlane)
-Hitting the right ramp (or under) consistently from both flippers. I was dialed in on this too.
-Usually (lol) the left ramp. I was NOT dialed into that shot that game. I think I hit it once during multiball.
#215 5 years ago
Quoted from Hougie:
Not a bad score for only one multiball jackpot!
Ryan Claytor
Elephant Eater Comics
www.ElephantEater.com
#216 5 years ago
Apologies to WOZ people for "stealing" one of their toys but I couldn't resist grabbing one of Tim Mezel's twistnados for my WW. Trying out the lower bumper location for now - I'll try to get it lit up sooner or later.
#217 5 years ago
Quoted from hootowls:
IMG_0009.jpg 243 KB
IMG_0007.jpg 194 KB
awesome! very cool mod.
#218 5 years ago
Some parts from Pinball Life came today that let me do a repair of something that had taken me quite a while to realize it was even a problem. One of those things that maybe you know isn't right but it takes a long time to get to the point where you really see it for what it is - for it to really register in your brain.
After switching over to LED I had some problems with a few 555 lamps in a couple of locations. Lamps not always lighting and others full on when they're not supposed to be. Slowly realized that they were all the lamps in switch matrix column #2 - the top drop target lane and the two outlanes.
The matrix says column #2 is transistor Q64 and, sure enough, the DMM says Q64 is bad.
Purchased a handful of TIP42 transistors for this order, just in case. R&R of Q64 and - sweet success - everything works properly! Finally, something that fixes the first time and doesn't make me hunt for it.
I hope those LEDs didn't get it too bad though. I understand that the failed transistor was probably letting through a lot more voltage than what they were looking for.
While I had the MPU out I also replaced all three of the diagnostic LEDs. Somebody had broken the two closest to the battery holder - not sure how that happened but it probably had something to do with those damn batteries. The ones I used have a clear lens (red emitter) so I did all three to keep them looking the same.
Still have things to work on but today was a good repair day.
#219 5 years ago
Project Spotlight. Added spots to light up the center corridor as I like low ambient light for playing, which kind of makes it hard to track the ball sometimes. Not anymore!
#220 5 years ago
Now I can join the club, I like WW better than my Funhouse so far.. My right sling shot is cracked if anyone has an extra I'll take. Just PM me..Thanks!
#221 5 years ago
I don't know about you, but my WW is consistently kicking my sorry a$$. I have very short ball times, and outlanes are not even wide-open... just in the medium position...
Every missed shot is a potential disaster. This game is highly frustrating but helps you play better - you need to be in control! My best score is 18 millions with no extra balls allowed.
#222 5 years ago
I've often though ww is better than fh. I also think the same about taxi being better too. Just couldn't get into fh.
#223 5 years ago
Quoted from Blackbeard:
Yeah Taxi is a great game too and for the money you can't beat it.. Just pure fun!
#224 5 years ago
Quoted from Choggard:
Funhouse / Whirlwind / Taxi was my lineup a few years ago. I wish I still had them all!
I would rate them
1. Whirlwind (Quite a bit ahead of the other two)
2. Funhouse (Just a tick above Taxi for the crazy talking head because I am weird like that)
3. Taxi (GREAT playing game when shopped out. SO FAST back at ya if you brick a shot..)
#225 5 years ago
Quoted from shanetastic:
I would rate them
Yeah I agree WW is just a step above FH and Taxi. Last week I had all three of these pins now my Taxi is gone and I am looking for a replacement for it. I think my next pinball will be a STTNG or WCS..
2011-05-13_23-07-43_585.jpg 206 KB
#226 5 years ago
I really like WCS. Very neat layout. I haven't been able to get into STTNG quite yet. I would like to own one day, get it dialed in, and put some serious gameplay time into it. So many seem to love that pin.
#227 5 years ago
I just scored my 2nd ever 20 million game.
Me and my dad were having our nightly game together.
Playing on a 3 ball game.
#228 5 years ago
Kudos, Mrgone!
#229 5 years ago
Quoted from mrgone:
image.jpg 187 KB
Every now and then mine has to remind me who's boss by giving me about a million point game. Whirlwind is not easy.
#230 5 years ago
Just stumbled across this thread - boy am I missing my WW!! It's been dismantled since April when I sent my DP PF to HEP. Hopefully I'll be getting it back the next few months...I can hardly wait!
Unfortunately, I had to sideline the rest of the restoration as I got side tracked by a move in August but I've finally gotten to a point where I can resume working on it again and have been working on the mechs, cabinet and such over the last few days. In doing so, I have a few question I'm hoping you might know the answers to. Here they are:
1) I'm sending all the pf posts and such out for nickel plating and was wondering was plating I should have done on the trough pieces, lift bar, switch box, etc? Those piece look to be galvanized but I don't know for sure and I don't know anyone that does galvanized plating. I would like to keep it as original as possible. Do you think zinc plating would work?
2) I picked up a couple of ball gate flaps from Marco to replace my badly rusted and pitted ones but their replacements are bare metal. Do you know what finish or plating was used to make them that blackish, bluish color? I was going to try some gun blue bit figured I'd check here first.
3) Does anyone have a source for black oxide plating/finishing? I'd like to re-do the back box bolts (and maybe the ball gate flaps?) but don't want to lay out the $70 for Caswell's smallest blackening kit.
Thanks,
Ian
#231 5 years ago
Quoted from mac622:
Suggestions (not from experience):
Gun Bluing - http://www.pinrestore.com/Supplies.html
Metal Blackening - http://www.eastwood.com/metal-blackening-system-set.html
#232 5 years ago
Thanks for the link to the Eastwood kit. I may give that a shot since its about half the cost of a Caswell kit and would probably deliver the results I'm looking for.
On an unrelated topic, can you tell me what size screws are used for your inlane guides? When I was tearing down my pf I noticed that 2 of the 3 screws on each side were #6 and the other was a #8. On my other pins they have always been the same size for all 3 so I'm wondering if they changed this for WW or if it was a hack done by a previous user? Both #8 screws also had a #8 t-nut so it wasn't as though someone was compensating for a stripped t-nut by jamming a #8 in there.
#233 5 years ago
Quoted from mac622:
Mine are all #6 as are the three in the ball lock lane.
#234 5 years ago
Same here. You could always tap out the bigger t-nuts and hammer in smaller.
#235 5 years ago
I'm joining the club in two weeks! can't wait!!
#236 5 years ago
I joined last week. Has been on my 'list' for 2 years, finally snagged.
#237 5 years ago
i want to snag a good one! close
#238 5 years ago
Patiently waiting for CPR to finish their list for this playfield so I can finally finish my restore... My first pin and the reason for my collection
#239 5 years ago
Funny reading posts about how many WW's are for sale at the moment. Over here in the UK I reckon once maybe twice a year one becomes available . Well in the public forum anyway.
Here's my February score. It's my best ever WW score. But I am poo
#240 5 years ago
I picked up my first pinball last week. A Whirlwind that is in pretty good condition. I want to make a few touch ups to the paint. Does anyone have a current paint mixture that I could use to match my paint as close as possible? Please be as detailed as possible. Thanks in advance
#241 5 years ago
http://pinside.com/pinball/forum/topic/whirlwind-paint-codes
Here's a thread with the paint codes I used. They're a great match for my Pheonix Arcade decals.
#242 5 years ago
I finally made it into the Whirlwind club! Been needing one to go with my ES for a while and scored a clear-coated one today. Playfield is stellar, cab is a bit rough but hey, you don't play that.
#243 5 years ago
Err.. maybe you guys could help me out? Just picked up my first pin (WW, obviously!) and have been working on a few things. Here is my latest endeavor.
http://pinside.com/pinball/forum/topic/whirlwind-spinner-off-center
I also have had a problem with the cellar door spitting out at random speeds, mostly very slowly. I read the solution but don't know where to start really - I am five days in and already over my head Anybody want to hold my hand on this one, or is trial by fire where I'm headed?
EDIT:
I dug around at Marco and it looks like I should just pick up:
http://www.marcospecialties.com/pinball-parts/AE-26-1500-01
http://www.marcospecialties.com/pinball-parts/10-149
Does that look right? PM me if you have time and patience!
#244 5 years ago
My cellar was spiting out randomly due to the wrong coil sleeve being installed there. IT needs a coil sleeve with a flanged edge. So in other words one like this:
http://www.pinballlife.com/index.php?p=product&id=2900
Without the flange, the coil isn't secure, and never hits the ball the same way twice.
#245 5 years ago
hi, can anyone post pics of both slingshot wiring,(mine kick together). also pic of wiring for switch#48 NE standup next to the right ramp. thanks for the help. joe
#246 5 years ago
is there any adjustment besides up and down on the spinning discs? mine don't seem parallel with the playfield all the way around.
#247 5 years ago
Quoted from Kneissl:
If up and down doesn't cut it, you could try washers.
#248 5 years ago
Quoted from joe2012:
Here's pictures of both slingshots. I'll see if I can find one of switch #48.
John
#249 5 years ago
Proud WW owner. <--- See my avatar...
Still my favorite pin ever. 2nd in my collection, but it will be the last to leave.
#250 5 years ago
I tell ya, I also own LOTR and Metallica. More often than not, WW is my favorite pin. It is so great on so many levels!
11,990 (Firm)
Hauppauge, NY
€ 3.70
$ 16.50
Metal-Mods
Gweem's Mods
Yorktown Parts and Equip
