(Topic ID: 235699)
Whirlwind center drain
By Azatar
2 years ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by chuckwurt
#1 2 years ago
Hi all. Recently picked up a nice Whirlwind. Whenever you hit the right ramp (the Orange SE target), the ball will always drain down the middle. This happen about 90% of the time. Is it supposed to do this? I have checked the pitch angle and made sure the game is level, and it checks out.
#2 2 years ago
The right ramp feeds back to the flipper lane. The SE target flanking the ramp can result in SDTMs.
#3 2 years ago
Thanks- yeah, ramp is the wrong word, it’s the right lane that acts as the se target. I’m just making sure it is supposed to center drain pretty much every time you hit it...
#4 2 years ago
If the target is bent backwards I'd worry about it, if not, you might be able to tweak its angle slightly. However, some shots are designed in machines to make the ball drain, since you can't have a game on a location that you can just play endlessly.
It's just pretty much a risky shot in that case that you have to learn to deal with by hitting it at an oblique angle.
#5 2 years ago
The right 'orbit', if memory serves, loops around to the pop bumpers. If that first bumper is flaky and not kicking the ball over to the other bumpers for some good ball action, you might see drains coming out of the left orbit/bumpers.
#6 2 years ago
Do you have the center post installed between the flippers? Seems unlikely to have that many center drains with the post installed.
#7 2 years ago
Yes, it has the center post installed. And if the right orbit is hit with any speed, it will pass through the lower bumpers and drain. It may be just by design, and requires a different approach, but I was asking to see if the setup might be to blame. Like I said, it is a new game to me, so I’m sure there are people with more Whirlwind experience than me!
#8 2 years ago
Quoted from Azatar:
It should always go into the pops and bounce around. If it’s not doing that, need to make sure your pops are working and they are nice and sensitive.
Watch this.
https://pinballvideos.com/v/1110
