I have a WW that does not boot up right away when turned on. When I turn the power switch on I get GI and nothing else (no display or inserts flashing). It takes about one minute then it finishes the boot up. Its like it gets some heat to it then decides to finish the boot up process and game plays fine after that.
When I first turn the game on I get a solid led at the 5volt, Diagnostics led flashes slowly (not quickly like normal) and the blanking led is off. After the game fully boots which takes about a minute I get a solid led at the 5volt, Diagnostics led flashes quickly and the blanking led is solid (which is all normal).
I tested the test points on the power supply and get these readings.
TP1 - 5V
TP3 - 11.9V
TP4 - -14.6V
CPU board
TP2 - 5V
So the question is why is this not booting up properly when turned on? Would it be worthwhile to rebuild the power supply board? Could this bad RAM? Any ideas?
Thank you
