New! Dark mode!
(Topic ID: 52350)
Whirlwind: Blower Light Mod 15 LED Version - 2nd run Shipping Now
By cranie
7 years ago
  • 36 posts
  • 23 Pinsiders participating
  • Latest reply 5 years ago by Wickerman2
Topic poll
“Would you be interested in this kit?”
  • Yes 20 votes
    87%
  • No 3 votes
    13%
(23 votes)
#1 7 years ago
I'm putting more kits together based on demand to add a light to the blower when it is on.
It's all self contained under the dome and takes about 15 mins to install.
Video here:
The kit is $45.00 shipped in the US
To order - Paypal $45.00 to cranie4@yahoo.com Be sure to include address
Mike
**Here are the instructions for installation:Whirlwind Blower Mod
While this can be installed with the back box in the upright position it may be easier from the lowered position. If you lower remember to undo the wing nut holding the ground braid inside the back box first ( if yours is like mine and not long enough to stay connected with the back box lowered).
Remove the blower dome (good time to clean it inside and out and also wipe the fan blades)
Find a location for the power converter to the left of the fan motor assembly that will allow for the wires to reach the fan motor tabs and keep the fan unobstructed and also allow for the dome to fit back on.
Secure the converter to the back box using the 3M double stick tape.
Solder one wire per side to the Fan motor tabs. Polarity doesn't matter as it's AC voltage.
Run the wires with the led to just under and behind the fan blades so it's centered underneath.
Peel the adhesive strip on the bottom of the LED and place it firmly.
Test the kit using the "Coil Test". The LED's should light when the blower motor activates.
Replace the dome and put the back box in it's upright position (reconnect the ground braid if it was disconnected).
ENJOY!
#2 7 years ago
That is super cool. I don't have a Whirlwind, but if I did....
#3 7 years ago
I like it. If I owned a Whirlwind, I would want one.
#4 7 years ago
Count me in!
#5 7 years ago
I have done this to mine as well. It is really cool.
#6 7 years ago
I'm interested!
#7 7 years ago
I did this to mine as well. This is an older video, as I have since replaced the original Warm LEDs with two Balrog CW Flashers so the higher voltage from the fan doesn't burn up the LEDs.
#8 7 years ago
I'd like to see the fan and clouds light up in sync with the lightning effect on the playfield and backglass. I think somebody has already done it though.
Chris
#9 7 years ago
I want a WW. PM me if you have a really nice one for sale. Then I will buy the mod.
#10 7 years ago
Quoted from mcluvin:
Chris
Like the one in my video? You just wire some sockets to the lightning board.
#11 7 years ago
Quoted from Capper96:
ยป YouTube video
Interesting to have the flashers tied to the ones in the back. My kit uses a converter to a LED strip.
#12 7 years ago
Did you just use some led flashers in there or 44s? No strain on the circuit? Just curious as I was going to do the same to mine.. looks killer..
#13 7 years ago
This is my version of shanetastics WW light mod he shared awhile back.
#14 7 years ago
Quoted from ZEN:
Both, the setup kinda looks like PinWillie's pictures above, but here is my current configuration
2x Warm White LEDs each attached to a GI rear lamp (might switch to UV)
2x CT "Balrog" Flasher 44 bulbs attached to the fan motor (higher voltage LEDs)
1x CT 9 stack Coolwhite 906 flasher on first lightning lamp
1x CT 9 stack Orange 906 flasher on second lightning lamp
1x CT 9 stack Coolwhite 906 Flasher on third lightning lamp
1x CT 9 stack Red 906 Flasher on the High Pressure flasher insert
1x CT 9 stack Blue 906 Flasher on the Low pressure flasher insert
The only issue I had was the fan frying LEDs after a while, but the Balrog higher voltage flashers seemed to solve this problem that i had.
#15 7 years ago
Quoted from pinwillie:
Looks cool....
Anyone have the link to his post about the mod he did? Would love to do it but need further detail...Thanks!
#16 7 years ago
I would be interested in one of the kits. Looks great!
#17 7 years ago
Quoted from Pinfactory2000:
http://pinside.com/pinball/forum/topic/shanetastics-whirlwind-2
1 year later
#18 5 years ago
I've had requests for the kit so I'm wondering if there is enough interest in the 15 LED version for me to do another run.
Let me know
Mike
#19 5 years ago
Also looking for a nice whirlwind. I would buy this mod now though while searching for my game.
#20 5 years ago
I'm in if shipping to Europe is possible!
Cheers,
Ken
#21 5 years ago
Yes, I would be interested in this for sure!
#22 5 years ago
in
#23 5 years ago
I'm down
#25 5 years ago
I'm interested as well.
#26 5 years ago
In.
#27 5 years ago
I am IN for sure, as long as it is the 15 LED strip mod and NOT the 3 LED version.
THANKS for doing this!!!
Dan
#28 5 years ago
Ok, there seems to be enough interest for a small run. I have ordered parts and with assembly time they should be ready by 3/13/15.
Preorder now by Paypal $45.00 to cranie4@yahoo.com and be sure to include your address
Mike
#29 5 years ago
Awesome! Order has been made. Looking forward to adding this!
#30 5 years ago
Mike
PLEASE make sure I get one ... PM sent to you!
THANKS so much for doing these again, I really appreciate it!
Dan
#31 5 years ago
First kits have shipped. Only 7 left so get them while they last!
#32 5 years ago
Sweet. Looking forward to hooking it up.
#33 5 years ago
So I got this today and just hooked it up. Yeah it is ridiculous! Just way too cool. If anyone has a WW they need this. It looks awesome.
#34 5 years ago
Thanks Josh. Enjoy!
#35 5 years ago
Still a few kits left to anyone who wants one. I most likely will not be doing a 3rd run for a long time so get yours now.
1 month later
#36 5 years ago
Quoted from cranie:
Put mine in--looks great!
2,500 (OBO)
Kittery, ME
$ 369.00
3,200 (OBO)
St. Louis , MO
Metal-Mods
$ 12.00
$ 54.99
Plymouth, MN
2,800 (OBO)
Sale Pending!
Heel, LI
$ 40.00
