(Topic ID: 71360)
Whirlwind ball lock/trough problem
By haffie96
10 years ago
#1 10 years ago
So I have this system 11B whirlwind which gives you 2 balls after you've locked one ball.. all the switches work correctly. There's about 3 seconds between it and then the coil goes of and gives another one... Does anyone also had this kind of problem with a system 11 3ball multiball machine?
And perhaps how to fix this?
#2 10 years ago
Take off the apron and see if the 2nd position switch in the trough is closing somehow.
Also check the 2nd ball lock switch.
I recently had an odd problem when 1 ball was locked the coil would sometimes all of a sudden kick the locked ball out while shooting the next ball around.
It was fixed by replacing the intermittently working 1st ball lock switch.
1 month later
#3 10 years ago
I had the exact same problem till lunch today:
http://pinside.com/pinball/forum/topic/whirlwind-keeps-kicking-out-two-balls-on-1st-lock-and-ball-2
Turned out to be a sloppy feeder.
4 years later
#4 5 years ago
I just want to add something to the big pinside pool of knowledge:
I had this exact same problem. intermittant and annoying. but only when one ball was locked.
i started to change switches one by one. after i changed the ball through 1 switch, the problem occured every time i had one ball locked.
It turned out to be a poorly grounded machine and an unwanted connection.
Every time ball lock 1 was activated AND the wire on ball through 1 touched the ball shooter. it would serve another ball.
a bit of bending of the wire solved the problem for good.
Precision Pinball prod.
$ 45.95
$ 399.95
Pin Stadium Pinball Mods
$ 27.00
$ 95.00
Pinball Mod Co.
$ 899.00
$ 18.95
4,600 (OBO)
Greenwood, IN
$ 44.99
Pinball Shark
Middletown, OH
$ 12.50
RoyGBev Pinball
7,500
Bakersfield, CA
$ 16.50
Metal-Mods
$ 399.00
$ 90.00
$ 54.99
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/whirlwind-ball-locktrough-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
