I'm trying to tie in two #44 bayonet lamps to the fan motor so they turn on only when the fan comes on. I wired them in parallel and
the lamps get too hot and burn up. So obviously this is not the way to go. I tried putting them in series and get no voltage. The
fan puts out 29vac when measured with a meter. The LED lamps are rated for 13vac. Can someone advise by looking at the diagram as
to what I'm doing wrong?
