(Topic ID: 269213)
Which wires test to jump test for non-energizing relay?
By flopflip
13 days ago
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 12 days ago by flopflip
    #1 13 days ago
    I have been gradually solving several issues related to the Startup sequence on my 4 player Bally Flip Flop. At this point, everything seems to be functioning, with one exception. The Game Over Relay Latch relay will not energize so the game remains in Game Over. All steppers in proper order and the other switches/relays involved in the Startup appear to be behaving properly. I have the Schematic and Manual but don't know which wires or connection may be causing the G/O Latch to not energize. Any suggestions on which connections I can test with Jumper wires?
    #2 13 days ago
    There are three switches that can send power to game over latch relay coil during the reset process:
    Score motor switch 8E - yellow wire and green/black wire (normally closed)
    Reset relay switch - green/black wire and orange/red wire (normally open)
    Score motor switch 4C - orange/red wire and green/white wire (normally open)
    If everything is working during the reset except the game over latch relay, then take a close look at the 4C score motor switch. Make sure it is clean and adjusted correctly.
    #3 13 days ago
    Thank you. I'll get right to it
    #4 13 days ago
    Should I attempt to jump these to see where the block may be? What about jumping the SCM 4C G-W to the Game Over Latch G-W (which is connected to the relay)
    #5 13 days ago
    I'd first try to clean and adjust (if needed) the switches... If you need to use a jumper wire, you can test the 4C switch by using a jumper wire between the relay coil - green/white wire - and the 4C switch - orange/red wire. And between the relay coil and the reset relay switch - orange/red wire. Yes, you can check for a broken wire by jumping between 4C switch and the relay coil with the green/white wire on both sides.
    #6 12 days ago
    Solved. Cleaned and adjusted lots of switches in the process, but it turns out the Game Over Trip armature was not seated properly. Now the Latch energizes.
    Thanks for the help! Onto the next issue!
    $ 29.95
    Pinball Photos
    $ 9.99
    $ 10.50
    The MOD Couple
    KAHR.US Circuits
    $ 89.95
    $ 96.95
    $ 76.95
    $ 29.00
    $ 69.99
    $ 12.00
    Medisinyl Mods
    $ 29.99
    $ 19.95
    Little Shop Of Games
    $ 7,599.00
    Operation Pinball
    $ 18.95
    $ 65.00
    G-Money Mods
    $ 229.99
    $ 40.00
    G-Money Mods
    $ 229.99
    $ 369.00
    $ 26.95
