I'm helping my friend with his newly acquired Black Belt, and we need to replace the coin door volume pot (in addition to the 1k pot on the sound board)... Couldn't find the ohm value of the pot in the manual, can anyone tell me what it is?
Can't find value of remote volume pot listed in my motordome manual either (unless I'm missing it)...does the current pot have the value stanped on it by chance?
Quoted from frunch:I'm helping my friend with his newly acquired Black Belt, and we need to replace the coin door volume pot (in addition to the 1k pot on the sound board)... Couldn't find the ohm value of the pot in the manual, can anyone tell me what it is?
Just meter the two outside leads on the existing pot and that will tell you the value (remove the wire leads first).
Quoted from girloveswaffles:Just meter the two outside leads on the existing pot and that will tell you the value (remove the wire leads first).
Not necessarily if it is totally open type bad, but if its just a worn wiper, then certainly should...or at least close.
Quoted from frunch:I never thought to look! I'll have my friend get a good look at it and report back.
If it is a metal cased pot like I'm thinking, values are usually stamped into metal case of pot.
My buddy's meter isn't working, so we're gonna go with Mk1Mod0's suggestion (100 ohm/5 watt) for the order I'm putting together. I'll be sure to check the original pot for resistance before i swap it out, just to be sure. Thanks for the assistance, everyone! I'll follow up when we install the new part.
Just checked Marco and the Pinball Resource, both have 100 ohm/2 watt pots. Will that suffice, or should i pick up a 100 ohm/5 watt somewhere else?
It does mount to a bracket in the coin door. Here's the one i found at Marco:
http://www.marcospecialties.com/pinball-parts/XO-199
This page was printed from https://pinside.com/pinball/forum/topic/which-volume-pot-for-coin-door-on-bally-6803-games and we tried optimising it for printing. Some page elements may have been deliberately hidden.
