An actual REAL solid state pinball machine?
As previously mentioned, Vacation America by Chicago Gaming.
(Otherwise the honor goes to Zizzle, as this is also solid state, but I don't even consider this a pinball machine)
Kings of Steel is an incredible machine next to this title (and a good backglass to boot).
Even a fully working run of this title is worth $400, and this is a later model solid state!
This is the same cost of a solid EM (non-collectible title).
Only 530 games were made for a reason.
Originally marketed near $3000, but most sold for much less.
The few owners left that have them may argue different, but the rest went into landfills.
It is not a "collector's piece" in any way shape or form.
It actually has a lot in common with Stern's future SM "The Pin" Version 2.0, in terms of direction for cost saving measures.
The game board and power design was fine, but it had WAY TOO MUCH reliance on cheap opto sensors for switches.
Additionally, if you had trace failures on the underside playfield boards, the game was toast.
If the LEDs or alpha numeric display burned out, it was toast.
Connector failure was another problem.
Most people never even knew how to provide maintenance to the game, unless it was a distributor that sold the game directly.
GI and insert lamps electrical voltage was "reversed" from most modern style games (GI was 12v) which meant you needed to read the manual or just constantly burn out bulbs from being completely ignorant.
Not to mentioned, repetitively annoying sounds, and bad playfield artwork.
The backglass was pretty good though, but it would have been better if they had actually licensed from National Lampoon.
If someone wants to sell me theirs, I will buy the glass for $200, and you can take the rest of the game to the dump.
I need one of these backglasses for my collection, but eventually one will show up to buy, unless someone throws a beer bottle through it first like the second Rocky movie.
It was not designed to operated in homes for more than a few years, unless rarely played.
This game is about 10X above in quality in comparison to Zizzle machines but not much more.
