(Topic ID: 221483)
Which is less likely to break? AFMre or MMre?
By sataneatscheese
1 year ago
  • 12 posts
  • 12 Pinsiders participating
  • Latest reply 1 year ago by HookedonPinonics
Topic poll
“Which machine is more durable, less likely to break and/or have mechanical issues?”
  • Attack From Mars Remake (SE) 17 votes
    85%
  • Medieval Madness Remake 3 votes
    15%
(20 votes)
#1 1 year ago
Still trying to decide between the machines. I've found 3 Medieval Madness remakes in arcades in my area. Every one had something wrong with them, broken draw bridge, gate that won't open, troll that won't pop up. I've only found 1 Attack from Mars Remake near me, but it worked perfectly. I don't see as many moving parts on it, and am assuming it is less likely to break. However, my experience may be a fluke based off of my location (DC metro). What is your experience with maintenance on these machines. Which one is more durable? I'm trying to decide between a MMre and AFMre SE for my first pin. Please answer poll and if you have any positive/negative insights please let me know.
#2 1 year ago
I'd get the game you like more.....these machines on route take more of a beating than they will in home use setting. Games will develop issues now and then...neither is immune. I like AFM more...so I'd go with that one
#3 1 year ago
Quoted from sataneatscheese:
Do more games break in DC metro? I never knew that.
#4 1 year ago
Every machine breaks. Also, no matter what game you buy, it can end up being a maintenance nightmare. Get the game you want. Then when something breaks, fix it.
#5 1 year ago
I've had both of the originals in my house for years. The remakes are mechanically identical, so I think my experience with them might be helpful. In my home environment, my MM has required more tweaking than the AFM, only due to the trolls. Occasionally I've had to tweak the troll switches to optimize sensitivity and sometimes tighten the plastic troll head that the ball strikes. That's pretty much it, and in my mind, a non-factor in choosing between the two, as adjusting the switches on the trolls are pretty simple, as is tightening the troll heads.
As you noted, the drawbridge and gate on routed MM's are often beat, but in a home use environment, you really don't have to worry about that, at least I haven't in 10 years of HUO play. You will want to protect the MM's Merlin saucer and the wood edge in front of the castle with Mantis and/or Cliffy protectors, but likewise, you'll want to protect the Stroke of Luck opening on the AFM as well.
These are both great games. AFM is mechanically simpler than MM, but in a HUO environment, I don't think this is much of a concern. You really can't go wrong with either game.
#6 1 year ago
AFM has more conventional mechanics, plus it's the newer game so they've had more chance to work out any kinks in their board design
#7 1 year ago
Neither is likely to break since they are new games but the trolls on MM are the most likely mechanical failure IMO. I also really don't like that on MMr they put driver transistors mounted under the playfield. In AFM they moved them to a board in the backbox which I like better. that being said, there are MMr's on location that have survived a lot of plays with little to no failures of electrical components. Also the first AFMr I saw on location had a trough opto problem and probably had less than 1000 plays on it so as with pinball, you will have to fix something at some point. Pick whatever game you like better and if you aren't sure which one you like better, go play them on location if you can.
#8 1 year ago
I've had my MMr LE for about 2 years. I only had to adjust some things out of the box when I got it. And the troll hit switches once so far.
Had similar issues with every game I've had.
Stuff breaks, that's pinball.
#9 1 year ago
Afm is an easier game to maintain than MM.
#10 1 year ago
If you are thinking a new game will not develop issues, you shouldn't be buying one. A newer machine is less likely to have board issues, but switches go out of adjustment, wires break off, and things happen.You either have deep pockets and pay a tech to maintain it or you learn how to repair it yourself.
#11 1 year ago
One operator has 25,700+ plays on AFM remake already.
Post 5421 of AFM remake thread
#12 1 year ago
I have 1,800 plays on my MMR since I got it back in November 2017 and the only thing I had to tweak was the spring on one of my trolls. Took 10 min. Like everyone has stated, get the game you want the most. Don't worry about things breaking. They all break but are fixable.
Anderson, SC
$ 69.00
The MOD Couple
7,800 (OBO)
Cincinnati, OH
$ 369.00
7,900
Bainbridge Island, WA
