(Topic ID: 254197)
Which fuse is which? Aces & Kings
By nibre
7 months ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 7 months ago by currieddog
#1 7 months ago
Which fuse is which? Aces & Kings (Williams 1970). I can only spot 4 but there are supposed to be 5...
#2 7 months ago
The 2 fuses on the left of the second picture are the same fuse. The schematic is just showing 2 wires come off that 1 fuse. 1 wire goes to the tilt relay and the other goes to the coin unit.
#3 7 months ago
The slo-blo is by the bank. It's the 5th.
#4 7 months ago
Quoted from edward472:
Two different fuses for two different circuits. One for backbox lights and one for playfield lights.
To my eye, those wire colors in your photo indicate these are (top to bottom) backbox lamps, playfield lamps, coils, main/line. This matches my WMS EM games.
If you can't ID the wire colors in your game (vs. color codes on schematic at lines on both sides of fuses), you could remove one fuse at a time and see what doesn't work. Although when you remove the coil fuse you will have to manually press the lock relay in briefly in order to see any of the playfield or backbox lighting, as the lighting circuits are normally enabled by this relay coil.
#5 7 months ago
1.
I have been studying the schematics closely (the colors of the wires and where they are going) and believe that the five fuses ar matched according to the images below. Ok?
2.
I didn't have a 1.6A fuse so I put a 2A fuse on position 5. Ok?
3.
Fuse 5 is marked "slow-blow". Fuses 1-4 aren't marked anything. Does this mean that fuses 1-4 are suppoed to be fast?
#6 7 months ago
Why did you change the slo-blo? It's important to match the fuses to the schematic, so the 2A isn't ok. And to your last question: http://www.learningaboutelectronics.com/Articles/Slow-blow-fuse.php
#7 7 months ago
There was a 10A in that place (position 5) and I changed it to a 2A. I thought it would be better than keeping the 10A. I will try to find a 1.6A but it seems like an unusual value...
Thanks for the link but I couldn't find the answer there. I believe that F1 to F4 are fast (the schematics don't tell but since they don't say "slo-blo" like F5, I assume the fuses have to be fast).
#8 7 months ago
Quoted from nibre:
Certainly better than the 10A. Slo-blo fuses handle surges. Without one you'll likely be blowing that fuse a lot.
$ 2.00
Doc's Pinball Shop
$ 2.00
Doc's Pinball Shop
$ 999.00
$ 5.00
Doc's Pinball Shop
$ 96.95
$ 29.00
$ 4.95
Apparel - Unisex
$ 65.00
$ 999.00
$ 48.00
$ 89.00
Pappy's Pinball Palace
Flashinstinct
$ 101.00
$ 24.00
PinWorlds
COINTAKER.COM
$ 149.00
$ 54.99
$ 54.99
3D MODS
