The game calls for a 22-600, which is in the game. I was having problems once in a while (only during multiball) with balls not making it up the launch wireform. I have the original wireform that goes over the R ramp.
I thought I would try a stronger coil, and I thought a 22-500 would be stronger (less windings, same gauge). The 22-500 was significantly weaker. Regular launch wasn't making it, and multiballs would fail every time.
I went back to a 22-600, but a brand new one, and it is much, much stronger than the 22-500, as well as the old 22-600.
I was always under the impression that less windings meant less resistance/stronger magnetic field. I know the mathematic formula is mind-boggling, but two coils with the same gauge wire, one with 100 less windings is weaker?
