(Topic ID: 249197)
Which clearcoat works best for spot acrylic touch up?
By Barakawins1
  • 16 posts
  • 9 Pinsiders participating
  • Latest reply 4 years ago by RWH
  • Topic is favorited by 17 Pinsiders
    #1 4 years ago
    Does anyone have good experience with a clear coat used to touch up some acrylic paint touch up? I've used brush on varathane but it smears over certain black
    touch up. Anyone have a good experience with another brush on touch up? This is just for acrylic touch up at inserts, not the entire playfield.
    #3 4 years ago
    I never received a response to this question so I experimented. I found that semi-gloss Triple Thick Water Based Varathane Polyeurethane works flawlessly over acrylic paints. It self levels when brushed on and one coat application acts as three. Hope that helps someone.
    #4 4 years ago
    Just a caution.. Use Water based Varathane "only". Otherwise yellowing will occur if oil based.
    #6 4 years ago
    Yup, water based poly works. If you're doing a small wear spot like kickout wear or ball drop, this works. I also recommend putting a piece of mylar in that spot, because it just going to keep getting hit.
    #7 4 years ago
    This stuff is great for chipped inserts, spot clears etc.
    #8 4 years ago
    Quoted from gjm7777:
    Where do you get this product?
    #9 4 years ago
    Quoted from RWH:
    I saw it available on amazon
    #10 4 years ago
    Quoted from brenna98:
    Yup, water based poly works. If you're doing a small wear spot like kickout wear or ball drop, this works. I also recommend putting a piece of mylar in that spot, because it just going to keep getting hit.[quoted image]
    I used this same Minwax recently on a touch up for a chip on the playfield and it worked very well.
    #11 4 years ago
    I've used the Minwax on several projects and I would think it's to soft for a PF but, if it works for you than go with it!
    #12 4 years ago
    Quoted from RWH:
    It hardens up...it just takes months, especially if you use it in a big blob. Thin layers of it dry faster I've learned...I use it to fill inserts in my restos.
    #13 4 years ago
    I have used createx 4030 balancing clear for small touchups to keep things from getting worse until I do a restore. Has been very good to me.
    #14 4 years ago
    I have also used 2 part auto clear over the 4030 when I did the restore without issues of the 2 mixing. I know you can add 4030 to acrylic for a stable mix wothout a top layer but have not tried that.
    #15 4 years ago
    Quoted from RWH:
    https://www.kbs-coatings.com/DiamondFinish-Clear.html
    Comes in various sizes. Word of caution, only use what you need in a separate jar and after transferring it make sure to put saran wrap in the original can before sealing the lid. If you dont, the lid can fuse shut.
    #16 4 years ago
    Thx it's good to know
    This page was printed from https://pinside.com/pinball/forum/topic/which-clearcoat-works-best-for-spot-acrylic-touch-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
