Quoted from NIW3:Hello,
I have a Gottlieb Cross Town machine built some time around 1966. I received it as a gift some time in the mid 70s. It had a fair amount of wear and tear on the cabinet at that time but was completely playable. It was played regularly for a few more years after that but it hasn't been powered up in over 30 years. The last time the machine was on, it would shut down (no blown fuses) as soon as the ball hit any target, bumper, etc.
I don't think I have the time or money necessary to fully restore this machine but I would like to get it playable. I understand that it is impossible to assess the condition of a machine from photographs much less not seeing it all. However, I'd like to know what is the correct sequence and process to follow to resurrect this machine.
First thing is that long ago, the keys to the coin box and back panel were misplaced. Is the only decision to find a locksmith that will make a house call or is there some workaround to get these open and re-keyed?
Thanks in advance.
The good news, is likely its just dirty switches. Old EM games that aren't played often, tend to get corrosion/dirt on the leaf switch blades. Playing a game, those are designed to rub against each side a bit to keep the contacts clean. Sitting for years, the contact between the blades is poor, many things can go away from just cleaning and adjusting switches, ball count is goofy, won't reset, score reels not resetting or struggle counting to the next digit, or game over / early switch close. A working game that sits and then doesn't work - 99% of time its switch contact related.
The game over right after a switch hit is likely a dirty/poorly gapped switch at the game over relay (gap being the space between two "leafs" on a switch - either they are touching = no gap, or too far apart, wide gap, or so dirty they are gapped correctly but not making contact across the dirt/corrosion). can be one switch or a chain of switches in a combination of relays. If after reading the pinrepair.com/em link and you decide not to try yourself, then you should have a pin repair guy come out for ~$100 and go through and clean the contacts and adjust the gaps on all the switches, clean the playfield and replace burned out bulbs. You may need new rubber on the game as well, 30 years and rubber gets brittle and crumbles or will break soon.
So Labor $60-120/hour depending on your location.
Parts - likely guess $40: couple 10 bulbs per box of #44 bulbs ~ $2 a box, rubber rings and switch adjustment tools, switch contact cleaner file, a small bottle of novus 1 for cleaning plastics/Playfield, get your stuff at Pinball life, easy to order, likely all in stock, good prices and Terry is just an excellent guy.
A game tech knows those quick maintenance things and likely get you up and running in an hour or cleaning and adjusting.
I'd encourage you to follow the pinrepair.com/em steps, and come back here and post progress or "I'm stuck, now what". We all started there and its actually pretty quick to learn the basics under the hood. EM's are simple on/off switches, and learning the path of on/off logic throughout the circuit of the path of switches.
