I've already added 4 more blatant oversights on my part to the list....sorry. That's why I'm posting it.
Reminder- Matt won't be doing the plastics ( right side unchanged, just color options, left side definitely shorter, and color options). I've reached out to a couple of Pinside modders to see if they're interested, as my hope is they can be sourced and purchased separately from a single provider. Will let you know what I find out.
You have two choices on how to proceed w plastics:
Easy way- leave the right alone and just cut the left yourself ( like my pic) and you're good.
Harder way- replace both plastics with colored versions. Right plastic identical in size, left will be the custom size. You will need to drill out rivets from the Cat brackets from original, and re-rivet to each of the new plastics. Not a biggie if you have the tool.
I'll make sure to add pics when I put the final assembly in my machine. This is really not that hard ( I'm sure it sounds harder than it actually is...pics will help).
