(Topic ID: 231406)
Where to get shorter legs?
By luckycreature
5 years ago
    #1 5 years ago
    So I have a really low basement ceiling. My TNA which is smaller than most pins siren is almost hitting the ceiling. Of course I have the pinball bug now and want to get more machines in the future. Can anyone reccomend me a leg solution if I buy any larger 90's Williams games or modern sterns?
    Thanks for any help or suggestions.
    #2 5 years ago
    http://www.pbresource.com/ Try Steve.
    Or get a taller ceiling. Think long term. Even with shorter legs. Can you lift a playfield up high enough to work on it with your ceiling ?
    #3 5 years ago
    Williams made 25 inch legs for the front of some of their games in the mid 60s. Find 4 of those and you're good to go! If you don't mind playing on your knees.
    #4 5 years ago
    How tall is your ceiling?
    #5 5 years ago
    I had the same problem with my Hercules in a drop ceiling area of my basement. I took the four legs to a machine shop where they cut off the end and welded a square block of metal that's 1/4' thick and drilled and taped for the leg levelers. Worked out great.
    John
    #6 5 years ago
    Quoted from jeffc:
    About 77 inches
    #7 5 years ago
    I don't know about modern Sterns, but here are the heights of my games with proper legs and with rear levelers pretty high. I think you will be fine as long as you don't do toppers.
    70.5" 1990s WMS NGG, WCS, AFM
    70.3" 1971 BLY 4MBC
    69.5" 1976 GTB Sure Shot
    71.5" 1976 GTB Surf Champ
    70.3" 1979 WMS Flash
    Pinball Resource sells 27" legs which are 1.5" shorter than most legs (28.5").
    This page was printed from https://pinside.com/pinball/forum/topic/where-to-get-shorter-legs and we tried optimising it for printing. Some page elements may have been deliberately hidden.
